Question about Miele Dryers
Miele -washer dryer-WT 2780 fault code 3
When put on the dryer
    Habit-Forming:
  • 64 Answers
Hi. Is your filter clean?
miele -washer dryer-WT 2780
Posted on Apr 27, 2017
Testimonial: "a filter is clean , I clean it. but the default code error 3 is there on dryer programm only"
  • andrew janus Apr 27, 2017
    Error 3 it's a NTC - sensor shorted- circulated air path/ fan. Basically your fan is shorted. Maybe brushes
Why is water not heating
Most washers require both hot and cold supply
Jan 06, 2017 | Miele Washing Machines
Miele washer does not power on at all
check the door switch or the mains fuse. they are both on the inside.
Feb 15, 2016 | Miele WT 2780 Front Load Washer
How do I get at the Motor on a WT 2780 Washing machine?
The most important thing you miss, is you should first diagnose what is defect. When 100% certain there is no cause for the defect other and died because of the usage and it is replaceable, you first should buy the spare part and then start the replacement. Without a manual I would not even start opening it. And when the motor costs more then half a new washing machine I would not even order one or replace one.
Please be careful when opening the machine. One mistake can cost your fingers or it even can cost a life.
Feb 09, 2015 | Miele WT 2780 Front Load Washer
What is fault 55
Water Temperature. 55 is the temp of the water. There is no fault code 55. By displaying this temperature, it's telling you that the washer needs warm or hot water. You could have a faulty water valve. See if it fills on hot. If it is slow fill on hot, it would also display 55.
Aug 02, 2014 | Miele Washing Machines
Fault 55
I had the same problem twice. I removed the top cover and on the metal part in the middel you see a reset button on the right side with 2 connectors. Push the button in the and it will work again.
Jul 17, 2014 | Miele WT 2780 Front Load Washer
Why is my Miele WT945 front lader washer dryer not taking water in properly or at all?
you may try cleaning the inlet screen by removing the fill hose.then pry the ccreen out with a small screwdriver.
May 05, 2014 | Miele WT945 Front Load Washer / Dryer
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Problem
Could you please describe the problem you are having a little better?
Oct 20, 2012 | Miele WT 2780 Front Load Washer
'Close the Door' on Miele WT 2670
Door lock faulty or wires to lock adrift.
Mar 06, 2010 | Miele WT945 Front Load Washer / Dryer
Dryers Logo
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
