HOW DO I GET VISUAL ON TV THAT IS PLUGGED INTO A SLATE LIGHT
VIZIO VW32LHDTV40A WON'T TURN ON. How do I fix?
Repair shop for a power switch module. If the machine was plugged into the wall, it got zapped by a voltage spike.
Aug 18, 2015 | Vizio Televison & Video
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
We want to connect our hp slate 7 to our Sony Bravia TV??
The Slate doesn't have any sort of video output. The only thing you may be able to do is run a DLNA server on the device that you can connect to watch videos.
If you're not sure how to setup your Bravia you can find instructions here:
http://www.youtube.com/watch?v=Zt9iPGJFiRs
Sep 26, 2013 | HP / Hewlett Packard 64GB Slate 500 Tablet...
HP Slate 500 won't turn on
It's not the power button. It's something else.It's dropped so there are a lot of problems inside the computer. Get it serviced. If the technician says that you need a new motherboard, then buy a new computer instead because motherboards are expensive.
David
Apr 09, 2013 | HP Slate 500 8.9 Tablet
How to install slate roofing
A slate roofing is actually a nice idea because its make your home quite pretty. To use slate roofing first you need better kins of slates its breakable also but now including roofing you should try another options like metal roofing, rolled roofing , its easy then slate roofing you can also visit http://andersonindustrialroofing.net/replacement/
Jan 12, 2013 | Roofing
Had ps3 plugged into main tv for some time. plugged it into another tv and it worked fine. plugged ps3 into original tv and i have lost visual, but still have audio. when plugged into second tv, still...
Try plugging something like a dvd or vcr into those ports of the TV, that will tell you if the tv is reading the PS3 wrong or the video is dead on your TV.
Sep 11, 2011 | Sony Playstation 3 (PS3) Console
Pictue but no audio on VHS playback..VHS record to DVD visual/no
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
Feb 01, 2009 | RCA DRC8300N DVD Recorder/VCR
Playstation
I assume you are connecting to your "old" tw with aydio/visual connections. Make sure that the yellow connection is plugged into the vide connection on your tv, not one of the audio connections.
May 28, 2008 | Sony PlayStation (PS) Console
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
