Question about Echo Garden
I moved and don't seem to be able to connect my echo
If i unplug my Echo,do I have to set it up again when I plug it in again?
Of course you can; as long as there's adequate wifi coverage, you can move Echo anywhere. As the others have noted, I have a spare power supply plugged in another room, and just move Echo back and forth. Echo takes about a minute to restart, is all.
Dec 27, 2017 | Garden
Do you need to keep0 echo dot connected to power line to work?
Yes it must be powered all the time. Amazon has
Evo - an intelligent Battery Base for 2nd Generation Echo Dot. ("Alexa" unlimited) (EVO 2 White) $35
This attaches to the Dot and plugs in to the power socket, then the power connect to the Evo unit. This allows you to use it not connected for up to 5 hours or longer on stand-by and you can easily move it from room to room without have to reconnect to the WiFi.
Jan 02, 2017 | Echo Garden
Disappointed..
having your phone drop many calls a day and hearing yourself echoing, it seems that you must've dropped your phone often,and with the messaging thing, how about you delete stored message in your phone inbox.
Jun 06, 2013 | LG Cell Phones
I have a snom 370 voip phone with the plantronics cs70 headset but there's a bad echo on the callers end so i got the snom wireless headset adapter but i don't know how to connect it. i also have...
We've never dealt with snom wireless adapter but the CS70 and HL10 lifter is a popular set for your phone. there are a couple of things you can try to cut down on the echo.
1. Make sure CS70 is proper distance from phone, minimum of 6" (12" from a PC)
2. Make sure round compatibility dial (located on left side of base) is set correctly. Most phones work on setting #1 (never between numbers)
3. Echoing is usually caused by an improper mix of incoming and outgoing volume. With a friend listening in you can make broad and minor adjustments for both (incoming: back of base (1-4) and +/- on headset; outgoing: bottom of base (a-d) and +/- arrows on back of base).
Following these steps should help you out.
Good luck from Headsets Direct - 800-914-7996.
Aug 18, 2011 | Plantronics CS70 Wireless Headset
Helo,my echo 3 scooter keeps beeping and doesnot move please help
hi, okay check the freewheel switch to make sure the switch is working ok, this is a very common problem, check the speedpot if there is any up and down movement I would question it,
If the rear disconnects, make sure the connections to the main frame are clean and connect ok as again if there's a bad connection here it will cause problems.
Regards
GeWiz.
Dec 13, 2009 | Shoprider Echo 3 Wheel Scooter
When i move the cord on my turtle beach x1 it gives me static and the mic echos when people talk. any ideas?
I found this on the Turtle Beach website: _________________________________________
If you or other players hear echoes in Live Chat:
Does it happen if you use the Microsoft communicator? Mute the microphone on your headset. Does the echoing stop? In the Xbox Dashboard > Settings > Live, set the voice to Play Through Both and unplug the talkback-controller cable. Does the echoing stop?
Echoing can sometimes be caused by high latency ("lag") on your internet connection. This may come and go depending on how much bandwidth is being used in your area.
If your talkback-controller cable's plug gets dirty, this can also cause echoing or static. Also check the input jack on the controller and make sure no foreign objects are in there.
Read these links for more advice:
Echoing can be caused by "a poor connection between the headset and the controller." http://support.microsoft.com/kb/912493 "The most likely cause is either a plug that isn't pushed all the way in, or gunk on the plug." http://xboxelle.spaces.live.com/Blog/cns!1pUP4M-J1d781v7Ac0Ta8FDw!158.entry "If you hear echo, then... someone in the chat session... needs to clean off their metal headset plug." http://majornelson.com/archive/2005/12/25/get-rid-of-voice-echo.aspx
Nov 30, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Open Questions:
Garden Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
