Question about Canon Office Equipment & Supplies
My canon fax machine has an error number e736. What do I do to correct this error?
  • 167 Answers
SOURCE: Samsung Multijet FX4200 Fax/Copy/Telephone
THERE IS COMMUNICATION ERROR , PLEASE CHECK THE PHONE LINE. HAPPY FAXNG OMNIPRESENT
Posted on Oct 02, 2007
SOURCE: Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Posted on Jun 08, 2008
SOURCE: Error Code for Fax Canon L220
You need to service machine and may be your fixing unit is problem
> If that replace Fixing Unit
Posted on Aug 15, 2008
copiersplusw
  • 136 Answers
SOURCE: Change fax number displayed on outgoing faxes
You need to go into your "Function" key- do you have the User's Manuel- if not you can go to canonusa.com- I am a USA Canon dealer so i can only refer you to the USA site, go here down load the User's Manuel- I haven't done it in a while but, i do believe you need to go into the Function mode the display "Set-Up" then change output preferences , I think your getting the " Sent " request- trust me get the User's Manuel and read it this should solve your issues you can download it right from the canon Website
Posted on Mar 05, 2009
SOURCE: We get a communication error to one specific fax #.
One of you has likely changed their fax machine/system recently, and simply put, some machines do not 'play well' with others. There are some DEEP programming changes that could be adjusted by a tech, such as "baud rate", etc. but for one location, it's not worth it.
Posted on Jun 06, 2009
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
When I try to send a fax to a 800 number or long distant, it dials and picks up then does that sound thing it does and then cuts off. The error says fax info does not match... the number is correct and we...
Does it work with local phones or is the problem only with certain places yo try to fax to? If it does, then there may be an incompatibility problem with some remote fax machines.
Jan 07, 2011 | Canon PIXMA MX310 All-In-One Printer
I get error code ##0103 on Canon LC3175 when receiving. What does it mean?
1) The user telephone number of the other party has not been registered for the autodialing function of the machine. or 2)The user telephone number has been registered wrongly for the auto-dialing function of the machine
Oct 12, 2010 | Canon LC-3175 Laser Fax
What does coms error 00E8 mean?
Canon FAXPHONE L120 Laser Printer Please follow the instruction as given below may this will help u any
Error Codes
An error code is a four-digit code displayed on the LCD or in the bottom row of a TX Result Report or an RX Result Report when an error occurs.
See the table below for individual error codes.
Error Code Description Action 0001 The sender may not be using a G3 fax machine. Make sure the sender's machine is compatible with your machine 0070 Reception was manually canceled on the machine. Ask the sender to resend the document if necessary. 0071 The machine's memory is full. Print, send, or delete any documents stored in memory. 0080 The recipient's machine did not respond within 35 seconds. Resend the document. Ask the other party to check their machine. If you are making an overseas call, add a pause to the number. 008D The recipient's machine has run out of paper. Ask the recipient to make sure that paper is loaded in their machine. 00A0 Transmission was manually canceled on the machine. Resend the document if necessary. 00A1 There is a document jam. Clear the document jam. 00FF All redialing attempts have failed. Check if the recipient's number is correct or the telephone cable is properly connected, and try again.
Aug 18, 2010 | Canon L120 Fax Laser Printer
Fax phone number
check the Cannon website for manuals on your model
Jul 09, 2009 | Canon FAXPHONE L80 Laser
I have a canon fax L250 i can send a fax but i can not receive a fax please help
Call this number (12723 12) from your fax line to ensure the fax number you are calling is the correct number. The service will repeat the number of the line you are on back to you.
Does a normal handset ring when plugged onto the fax line and called?
Is the fax machine in manual or auto-receive mode?
Mar 02, 2009 | Canon FAX-L250
Machine ID
Press Dataregistration-set-usersettings-set ,change the name and number in this mode.
Oct 30, 2008 | Canon FAX-L900 Plain Paper Laser
Canon fax problem
Can you send?
Are there any error messages?
Is the other party dialing the correct number?
Is the phone line plugged into the LINE port?
Oct 28, 2008 | Canon FAX-L800 Plain Paper Laser
old marine
old marine
