Question about Intel Palm Tx Handheld
Palm TX error(sys0505)(0,041)
When I reset my TX I get this error message.
  • waynesel Aug 08, 2009
    Thank you.
  • 296 Answers
Hi, You could try uninstalling Docs to Go on the TX and then reinstalling it. To reinstall, open Docs to Go desktop and under tools you'll see an option for reinstalling on the next hotsync.
If that doesn't work, you might need to take more drastic measures, like uninstalling Documents to Go from the TX and the Desktop PC and doing a full reinstall.
Thanks! mannu_rakesh
Posted on Aug 08, 2009
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
Palm unable to read card
Usually you just need to reformat the card to fix it. It may be reable in a pc/laptop so you can get anything important off first. Reformat copy your stuff back on and you should be good to go.
And yup this happens rather randomly and at the most annoying time possible usually ;-]
Mar 19, 2010 | Palm TX Handheld
Have a palm tx ,When calendar is chosen,the handheld crashes.
You probably need hard reset because there is most likely a corrupted program that is messing it up. I've gone through over ten different times where I had to hard reset. Get used to it.
Feb 12, 2010 | Palm TX Handheld
Tx will no longer sync with outlook 2003 or outlook 2007 calendars. Software reinstalled, tx reset, latest updates for syncing with outlook 03 and outlook 07 loaded, still won't sync to outlook calendar...
I would recommend contact the palm free chat. Here is a link for that. I have a TX and have used the chat feature myself and always with good results. Scroll to the bottom of the page and then you will see Palm chat. From there click on chat now and follow the directions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
Nov 18, 2009 | Palm TX Handheld
When you do a hard reset:
Yes I would remove first
Aug 07, 2009 | Palm TX Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
Still getting error (sys 0505) 0, 841 on Palm TX
Try a hard reset and wiping it out. Then resync it with the newest Palm Desktop manager 6.2
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 27, 2009 | Palm TX Handheld
Email errors
I would erase the TX memory and reload the software.
The TX memory can be erased by pressing the reset button in the back of the unit while holding down on the power button. Press yes to confirm delete.
Reload Palm software from CD.
May 19, 2008 | Palm TX Handheld
Intel Palm Tx Handheld Logo
29 people viewed this question
Top Intel Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an Intel Cell Phone Expert? Answer questions, earn points and help others
