We have to push the on button on our TV from 20-100 times to get it to turn on. Have changed batteries and restarted to no avail.
2 Suggested Answers
virka123
  • 6 Answers
SOURCE: my sony tv want turn on . when i push the the
if does not solved the problem by unplugging it for long time, thetrouble is hold down, mostly in sony defective resistor is causing holddown.as far as i know ..evn i had same problem wid my sony wega few mnths b4..gudluck.
SIGNATURE:WATCH TV SHOWS ONLINE IN HD including your fav shows ,hells' kitchen,America's next top model ,Oprah winfrey episodes and lot more
Posted on Jun 23, 2010
"He said our TV has a problem". Brilliant! To be more specific, he could have suggested switch failure or a failing power supply.
Apr 26, 2017 | Samsung Televison & Video
I have a Sharp LC-42D62U AQUOS TV. As a result of my grandchildren pushing buttons, inputs 1 and 2 are no longer available. We have followed every proceure in the operation manual to correct the problem to...
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 27, 2008 | Televison & Video
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I have a Samsung LN40c530F1F and I accidentally pressed the button below the power button labeled "DVD receiver/TV" and now nothing works at all on the remote. I have tried re-pressing the...
Take the battery out like about hour for a hard resetting.After putting the battery back in u should push the button that said TV only.The remote should be functions again for the tv again.
Jun 18, 2011 | Samsung LN40C530 TV
I have the black Dish Network remote. I pushed the "TV" button at the top to turn on the tv. It then turned red and I was able to push power and the tv was on. Then I pushed the...
Hello, the remote can sometimes have problems. If you haven't changed the batteries in 60 days, try different batteries, or even try a different brand. Sometimes also, with new remotes, the remotes can be faulty upon arrival. If changing the batteries doesn't help, then at that point, we would probably want to replace the remote again. It has been some time since you posted, but if you have yet to get this resolved, I would be more than happy to take a look into this for you. You can reach me at becki.barned@dishnetwork.com.
Becki Barned
DISH Network Customer Service
Nov 09, 2010 | DISH Network IR Remote Control
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
