I've asked this problem 3 times today with no response!flip 3 shuts off without warning. Tried reset procedure repeatedly. Do I send it to you or take it to the store?
Send a return address and/or I.D.number if needed.P.S.who the h... is Fixya?
  • 2,189 Answers
Take it to the store
fixya is a site where you post a question and wait for someone to come along and read your questions and decide if it makes sense then decide if they have a suggestion to help then answer your question
fixya does not repair anything , it is you that decides to do the repair or carry out the suggestions in the answers given
Posted on Apr 27, 2017
On an 2005 Chrysler 300 how do u fix when the flashing red thunder bolt symbol comes on
There is a problem with the electronic throttle control. Check to see if you have any stored DTC's in the computer, using a scan tool. It may be a glitch and needs to be reset. To reset the system and trigger the throttle calibration program
1) Insert ignition key and turn to "ON" (not start).
2) Wait for all warning lights to go out. Check Engine Light may remain on.
3) Slowly depress the accelerator pedal all the way to the floor.
4) Slowly release the accelerator pedal until it's all the way back up.
5) Turn the ignition key to "OFF".
6) Start the engine.
Most drivers notice an immediate change in throttle response, but depending on your driving style, you may need to repeat this procedure periodically due to the computer's adaptive programming. You likely need to repeat this procedure any time the battery is disconnected.
If there are DTC's, it may be a problem with the gas pedal position sensor or the throttle body.
May 02, 2016 | Chrysler Cars & Trucks
Hawking HW2R1 repeater doesn't get internet
first of all bring the repeater closer to your router (after upgrade you can return it to its original location)
Mar 25, 2017 | Hawking HW2R1 Dual Radio Smart Repeater
Flip hd killed my computer
Since your computer continues to reboot, I doubt it's your power supply. What you should try to do is to boot up in Safe Mode. I am sorry I can't be exact as to which key to press because it varies among brands. It could be Delete, F12, F11, F2 or something else. To try these, start your computer and rapidly click one of the above keys. If it doesn't work on one, try the next. You really need to get into Safe Mode so you can Restore your computer to a time before you placed the FlipHD into the port.
Jul 29, 2012 | Micro Electronics PowerSpec 8250 PC...
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
Memory card won't format continues to ask yes/no erase memory and then repeats after selection is made, can't get to the menu when new cf card is in
I've tried to send you a message 3 times so far today - not sure if this helps but a tech site suggested that the max capacity tested for the HP 318 was 16 MB - my card that I tried today was 8 gigabytes ..
I ordered a 16 MB card - hope it works. Good luck to both of us!
Feb 06, 2011 | HP Photosmart 318 Digital Camera
Photosmart C6180 All in one printer will not start although live
Strange because I have the same issue, and I've had this printer for over 3 years but the problem just started about a month ago.
I reset the printer by: 1) Unplug power to the printer 2) Hold #6 on the keyboard 3) Plug power cord back in while holding #6 Eventually (10 seconds?) the printer will shut down. Once it does, release #6 and power up the printer again.
Warning: This reset all the configuration settings.
This works for me, but there is still an issue because I have to repeat this every time I turn off/on the printer.
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Change oil soon light. how to get it to shut off
Answer The "change oil" light on a 2001 Grand Prix is reset by pressing the gas pedal three times while the vehicle is in "accessory" mode:
1. Turn the car off.
2. Place the ignition key in the "on" position, without starting the car. That is, turn the key forward to the place right before it fires the engine.
3. Place your foot on the gas pedal and press it all the way down three times, waiting approximately one second between presses.
If done correctly, the "change oil" light will flash repeatedly, and will then reset.
Please note that it is rare to do this successfully on the first try; if it does not work, turn the car off and try the procedure again, varying the wait slightly between pedal presses at each attempt
Apr 16, 2009 | 1998 Pontiac Grand Prix
2005 ford freestar reset light on
Vehicles Without Message Center To reset the system, press and hold the odometer reset button and wait for the "TIRE PRESSURE SET" light to illuminate. Continue to press the button for 3 seconds, then release. After 3 seconds, the low tire pressure warning lamp will flash 3 times, indicating that the low tire warning system reset procedure is complete.
Vehicles With Message Center To reset the system, press and hold the SETUP button and wait for the message center to display "REST FOR SYSTEM CHECK". Then press the RESET button and wait for the message center to display "HOLD RESET TO RELEARN". Press and hold the RESET button for 3 seconds. The message "HOLD RESET TO RELEARN" and the low tire warning lamp will flash 3 times, indicating the reset procedure is complete.
Mar 12, 2009 | 2005 Ford Freestar
Kenwood 7100
Airbag Warning Light Reset Procedure:
The reason for this is that you turned your car on with the airbag warning light for the passenger located in the vent panel above the radio disconnected. To reset it. Turn your car off. without starting the car (foot off the brake) Turn the car to the "on" position. wait for the airbag light to blink. The SECOND it goes off before it comes back on and blinks you need to hit the button again and turn the car off. wait 2-3 seconds and repeat 3 times.
Oct 23, 2008 | Kenwood DNX7100 Car Video Player
Acer AL1711 17" LCD Monitor goes blank without warning
The need to reboot your computer to get your monitor working places the blame totally in the computer. You have a virus, or the computer is overheating and shutting down for thermal reasons.
Jan 26, 2008 | Acer AL1711 17" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
