Question about Refrigerators
I have a french door fridge and it stopped making ice. Is there a reset button or something?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
No. There several things that can cause this problem,valve,freezer temp, bail on ice maker down, cube stuck in ejector fingers, open high temp cutout, or a dead ice maker
Posted on Apr 27, 2017
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
SOURCE: Maytag refrig (french door) water and ice on door stopped.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Posted on Dec 07, 2008
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
  • 1891 Answers
SOURCE: Ice maker quit working
go back to your sales people this is under warranty and it's propably a system problem . don't void warranty . // hold on i thought the sysem had failed . ice maker must be 15 deg or lower . to work ... close the drawer and give it 24 and see what it will do . but it is still under mfg warranty . **** ..
Posted on Jan 06, 2010
  • 289 Answers
SOURCE: LG er 15
is there ice or frost forming on the back wall.
Posted on Jan 16, 2010
The refrigerator portion is freezing ice on back wall, and the temperature is running itself upto 54. We have unplugged it and hoping it resets itself or something.
If you've got ice on the back wall but 54 degrees in the front of the fridge, that points to an air circulation issue. Ensure that there is air blowing out from the back of the fridge where the ice is, and also make sure that you don't overcrowd your fridge.
Nov 01, 2015 | Samsung RF265AA Bottom Freezer French Door...
Ice maker stop making ice put in new filter
probably filter backwards? or wrong filter?
why did u put new filter in? cuz it stopped already, and thought new filter should fix problem? u guys kill me
Jan 01, 2015 | LG LFX25960ST Stainless Steel French Door...
Samsung French door fridge is making an intermittent "whooshing" noise. It's still cooling and making ice and I don't see any frost or standing water in the fridge. Any thoughts or advice would be a
These fridges go through all sorts of cycles, the defrost cycle is probably the noisiest, strange sounds are ok, it will tell you when something serious is wrong, alerts & alarms.
Nov 16, 2013 | Samsung RF265AA Bottom Freezer French Door...
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
Every half hour or so it sounds like a power surge...an electrical sound coming from the upper section of my French Door bottom freezer refrigerator. I do not have the water hooked up for ice making...and...
You have a problem with the control board program. If the ice making button is turned off, the ice maker should stop working completely but it sounds like it's wanting to make ice.
Jun 28, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Having problems with ice maker. Was slowing down it seemed in making ice... and now it does not seem to be making ice. I tried the fast freeze ... still no ice. Obviously must be a water problem... the...
I had the same problem and the Samsung customer service person told me to set freezer to -2 degrees, remove the ice bucket, press and hold test/reset button (look for arrow on top right of ice maker inside the fridge), replace the ice bucket and wait 24hrs.
Dec 02, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
Nov 29, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
