Question about JVC Car Audio & Video
I have Jvc kdr 456 on caravan need instructions to change outside speakers to inside
2 Suggested Answers
  • 163 Answers
SOURCE: I have Jvc kdr 456 need instructions to switch sound between speakers
Its called a balance button L + R, F + B
https://www.wavetech.co.nz/jvc-kd-r456/
J Dana Taylor
Posted on Apr 27, 2017
Jc kdr 456 radio won't work cd plays fine
If the unit acts like it is tuning the radio (shows the frequency, etc) but all you get is static, I would focus on the connection to the antenna.
Jun 30, 2017 | Car Audio & Video
How to remove protect sign from JVC KDR-416
Sounds like you have a speaker wire shorted or touching. Pull stereo out of Dash But leave wiring harness plugged in. With stereo off unplug positive and negative of one channel or speaker then power on to see if it starts to work. If it still says protect shut back off wire that channel back up and go to the next Channel. As you do this one speaker output should be the culprit. If you go through all 4 and it still says protect then it may be a problem within the unit itself
Oct 01, 2016 | JVC Car Audio & Video
How do I wire a on on toggle switch between 2 sets off auto radio speakers 1 set inside the caravan 1 outside the caravan?
go to radio shack and get a speaker switch,connect them to the unit and you should have no issues its simple and easy.
Sep 25, 2014 | Pioneer Car Audio & Video
Warning check wiring and reset kdr-326
hi johan, firstly have all the speakers in vehicle checked individually. next check that all speaker connections have been done neatly. if problem persists then have the unit alone bench tested, and if problem appears again then the fault in definitely internal..good luck. cheers.
Sep 27, 2013 | JVC Car Audio & Video
JVC car audio cd receiver model # KDR-310 will not stay powered up. Shuts down after 2 seconds. What's wrong??
hi marnie, if all the power and speaker cables are connected correctly, then you might have a faulty or shorted speaker in the vehicle.your unit is sensing a fault condition. check the impedance of eack speaker connected to the unit from the harness plug. if this does not help then your unit needs to be bench tested.
May 23, 2012 | JVC AM FM CD DET FACE CAR STEREO
My cd's wont play and my ipod but radio works on my jvc kdr 520
Are you talking about just the audio coming from cd's and ipod? If so, are you using an amplifier? If you are using an external amplifier, you may be using the blue wire (power antenna remoter turn on) instead of the blue/white wire ( amp remote turn on) to turn the amp on. The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
Feb 21, 2012 | JVC Car Audio & Video
I have purchased a car with a JVC KD-R206 Car CD Tuner fitted but have no owners manual. Could you assist please?
http://books.jvc.com/booklist.asp?Model=KDR
Here's the link to JVC's customer support page for KDR receivers the closest I saw was the 200 and the 208. Most Manufacturer's will make several different model #'s of the same radio depending on where it's sold. Open the pdf's and see which one looks like your's. it may even be listed on the pdf front page. Hope this helps
Jun 18, 2010 | Car Audio & Video
By attaching amplifier with speakers and dont attach woofer there is increase in volume or not? my audiio system model no. KDR-506AND MY SPEAKER MODEL NO. 6922
No, it night seem like it because there will not be any low fequency noise from the sub to match. But, if your bass overpowers the rest of the sound you will need to put an external amp to your mids/tweets
Jan 29, 2010 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
