Manual time setting - Audio Players & Recorders
How do I adjust the settings on a 625-236 atomic clock
If you have a Howard-Miller 625-236 atomic clock, do you need to change the time zone only or manually set the time?
To set the time zone, press Mode (furthest left on the back of the clock) to get to the Alarm Time Mode. Then press Set (2nd from the left) to change the time zone. Then press Adjust (the middle button) to select the correct time zone. Press Mode again to exit the settings mode. To manually set the time, you need to remove the battery from the clock. Then reinsert the battery after 30+ seconds. Press and hold Set until the hour begins to flash, then press Adjust to change the time. Press and hold to quickly change the hour. Then press Set to change to the minutes and use Adjust to set the current minutes. Repeat this routine to set the seconds, month, date and year. Press Mode to exit to the Time mode.
The manual is available here: http://www.theclockdepot.com/howard-miller-625-236-techtime-operations-manual.pdf .
I hope this helps.
Oct 06, 2014 | Home
Can not change time zone on sharper image model lm521 projection clock
I got to liking the Sharper Image LM521 Digital Clock so much that I finally took the time to figure out how to manually set it-it was that or toss it! The instructions are as follows:
NOTE!!!
AFTER installing fresh batteries, or removing and reinstalling the batteries:
Successively pressing the "SET" button results in steps 1.) to 11.) below, each of which describes the particular/specific LM521 clock function you you can manually set.
HOWEVER, pressing the "SET" button after the clock had been previous set and running, will start the manual clock settings from step "2.)," "SET Offset Hours..." To start from step 1.), remove and reinstall the batteries.
PROGRAM/MANUAL SETTING MODE
After inserting the batteries:
The whole LCD screen lights up showing the different settings, etc.
After several seconds, the LCD screen clears and displays:
A flashing antenna
Upper left hand side of the LCD display. USA Time Zone Map
Middle right side of the LCD display (if necessary, to see, remove and reinsert batteries).
WAIT FOR AUTO TIME SET
A flashing antenna
> This indicates the clock is trying to auto set the time according to the WWVB radio/satellite time signal. Set on windowsill for best chance of success.
If it can't detect the signal, mannual setting is required, starting with the time zone.
> Manually set time ONLY if you are absolutely certain the WWVB signal cannot be found. Otherwise any manual time setting will be auto set to the WWVB time when its signal is detected, which may be many hours later.
SET USA Time Zone
1.) Press "SET" -- US time zone
> press "MODE" repeatedly until the desired time zone is reached.
5 = Eastern standard time (default setting)
6 = Central standard time
7 = Mountain standard time
8 = Pacific standard time
9 = Alaskan standard time
SET Offset Hours to Compensate for Satellite Signal
2.) After step 1.) above, press "SET"
A flashing "-7h" (minus 7 hours, default) and flashing USA Time Zone map appear.
This default setting worked just fine in New Mexico, MST, and may also work for your time zone as well.
> Press "MODE" to set from "-0" to "-12h" (minus 0 to 12 hours).
> Set to "-0h" if the satellite time signal set your clock to the correct time for the US time zone you live in.
> Set from "-1h" to "-12" to offset the time set by the satellite signal in case it does not match the time in your time zone. (E.g., 3pm -1h = 2pm.)
> NOTE: The default setting is -7h. If the satellite signal resets the time, say to 9pm, the time displayed will be 2pm (9pm-7h)--but if it should display 5pm instead to match your time zone, then set offset to -4h. Hence, the need to correctly set the offset hours if the -7h default value does not work for you.
SET Daylight Savings Time (DST)
3.) Press "SET" -- DST (Daylight Savings Time)
> Press "MODE" to set ON/OFF
SET Time
4.) Press "SET" (5no = seconds)
"5no" displays, plus flashing bars for seconds (not minutes as it falsely seems).
> Press "MODE" to set from 0 to 60 seconds
5.) Press "SET" (set hours)
> hour bars flash > press "MODE" to set hours
6.) Press "SET" (set minutes)
> minute bars flash > press "MODE" to set minutes
SET Date
7.) Press "SET"
> press "MODE" set year
8.) Press "SET"
> press "MODE" set month
9.) Press "SET"
> press "MODE" set day
SET Week Day
10.) Press "SET"
> press "MODE" set week day, Mom through Sun (Mo is default)
SET Standard (12) / Military (24) Time
11.) Press "SET"
> Press "MODE" set 12/24
CEILING DISPLAY:
SET/ROTATE Ceiling Projected Time/Temp Position
12.) Repeatedly press button with four tiny arrows pointing opposite each other (rightside of "DSPL" button) until the Time/Temperature display on the ceiling is oriented how you want it.
SET Ceiling Projection Brightness, or turn off
13.) Pressing button with sun symbol (leftside of "DSPL" button) cycles ceiling display from off, to brightness levels 1, 2, and 3.
SELECT between Ceiling Projected Time, Temp or Both
14.) Pressing "DISPL" repeatedly cycles between M0 (time), M1 (temperature), M2 (time & temperature auto switch every second or so).
Jan 23, 2012 | Audio Players & Recorders
I have an ACURITE 00590A1-RX. My time is off by 10 minutes. i don't have my manual and would like to know how to reset it. If possible, tell me how to download a manual.
From the manual, such as it is:
Set the Time Manually:
If you want to set your alarm clock a little ahead or if the unit ever loses time for any reason, the time can be set manually by following these steps.
1) Press and hold the "CH./SET" button for seven seconds to begin the manual time set mode. (2 BEEPS) The hour will flash on and off.
2) Adjust each setting by pressing the "+" or "-" buttons. Confirm and move on to the next setting by pressing the "CH./SET" button.
MANUAL TIME ADJUST SEQUENCE: hour, minute, year, month, date
This works for me. You have to be sure to keep pressing the CH/SET button for the full seven seconds -- the first beep the the clock gives you will only allow you to set the time zone and DST function.
Aug 25, 2011 | Acu-Rite AcuRite 00592A2 Wireless Humidity...
How do I change the time on my tom tom
The clock on your navigation device is automatically synchronised with the satellite clocks. You can also set the clock manually, for example when the device is indoors and unable to receive a satellite signal. The default setting is to automatically adjust the clock for the current time zone.
How to change clock settings To select the time format and to set the time, follow these steps:
Open the Main menu and tap Settings.
In the Settings menu, tap Set clock.
Select how the time should be displayed, then tap Next.
When you do not have a satellite signal, you are asked if you want to set the time manually.
Note: Since you need to be outside for your navigation device to receive a satellite signal, you might want to immediately set the time manually. The device will then set the time automatically when you next take the device outside.
Tap Yes to set the time manually or tap No to set your device to update the time automatically using GPS satellites.
Hope this was helpful. Thank you for using fixya.
Jan 26, 2011 | Tomtom GPS
HOW DO i SET THE WOODS 59203 TIMER LOST DIRECTIONS
Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
The picture shown at fixya for 59203 is not correct.
Picture shows 49112 which is also TD1000:
Manual for 49112-TD1000:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
Manual for 59203:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Manual shows 15 steps.
Plug timer in to charge battery. If battery will not charge, then timer is bad.
Set current time.
Set program1 ON time.
Set program1 OFF time
Set program2 ON time
Set program2 OFF time up to 20 pairs of ON-OFF times.
When programming is complete, press ON/OFF/Auto until Auto shows in display.
Add a comment of you need help with specific programming.
Nov 28, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
I'm having trouble setting this item. I can get it to come on, but it won't turn off at the set time. What am I doing wrong? Thanks, Janene
I don't have a Woods 59112 Manual
Here's link to Woods 49063 manual aka Woods TD1000 aka Noma TD1000
If manual is same/similar as your manual, then read solution given below
If solution below is incorrect, the write out your instructions ... I found that writing out instructions makes things clear.
Solution:
I think you have set ON time but did not set corresponding OFF time
Below is whole programming layout for you to read through
The important thing is to look at the display while programming
For example, lets say you are setting ON time for PROG1
For ON time, the display shows 3 things:
-display shows PROG in upper left corner
-display shows the number 1 to right of time
-display shows the word ON to the right of the number 1
Now you want to set OFF time for PROG1
For OFF, the display shows 3 things:
-display shows PROG as before
-display shows 1 as before
-display has changed and shows the word OFF to right of number 1
Here's how to set Woods TD1000 timer
Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set current time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 05, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Time is six minutes late
Manual Time Adjustments
Some people like to set their clocks 5 to 10 minutes fast to make sure that they will alwaysbeontime.EventhoughtheSmartSet® setsthetimebyitself,youstillhave the option of adjusting the time manually if you wish.
To manually adjust the time display depress and hold the TIME button, and press either the SET (Up) or SET (Down) buttons to adjust the time display ahead or back as desired.
Each press of the SET (Up) or SET (Down) buttons will change the display by one minute.
If you hold the SET (Up) or SET (Down) buttons the display will continue to change. The display will change slowly at first, one minute at a time.
But if you continue holding the SET (Up) or SET (Down) buttons the display will change rapidly.
Note:If you manually adjust the time, your new setting is entered into the SmartSet® memory. If the power is interrupted, the display will return to your new setting, not the original setting, when the power is restored.
Sep 23, 2010 | Emerson Smartset Clock Radio
S10Scan atomic clock model 87310 time is 4;pm should be 10:am
Hi
Time zone setting
Language Setting
The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
1. Set the desired language for the weekday display in LCD 2 by use of the + key.
2. Press the SET key to enter the mode “Manual Time Setting”.
Manual Time Setting
In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
Note:
In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
3. Press the SET key to move to the “Year Setting”.
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
for more details see user manual...
Thank you
Dec 12, 2008 | SkyScan 86709 Atomic Wall Clock
Garmin 205 running watch/ need to set actual time
It was only now that i saw your original post
One option is to touch the time settings in the top right. You can then change the time. Another option is below.
To update the time.
Go to Tools> Settings>Time
Time Format select either 12 or 24 hour time format
Current Time - you can manually set it or automatic to have the nuvi set the time based on your location.
The link to the manual is below as well.
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
http://www8.garmin.com/manuals/2459_QuickStartManual.pdf
Oct 13, 2008 | GPS
Set CD Clock Radio for Daylight Savings Time
just found a manual for another radio..timex website worthless but you hold the time or time set button down till the display starts flashing..then push the >>
Mar 11, 2007 | Timex T309TT Clock Radio
 Grubhead
Grubhead
