Question about Electrical Supplies
Genny is not getting fuel - Electrical Supplies
    New Friend:
  • 46 Answers
Check to make sure the valve is open.
Disconnect at filter and check for blockage.
Posted on Apr 27, 2017
Hi , I have a 2500 watts honda generator , it's starts & sounds alright but when you plug a power tool and once you press the trigger of tool it shuts off right away ... What could be the problem ?
Wow, you must have one mighty bit power tool there. The Honda genny should accept it easily. You don't mention the current draw of that power tool - it should be under approx. 2200W to allow for start-up load. The other possibility is an excessively long power cord or even a short-circuit in the tool ...... or a problem with the genny itself! Try plugging in your wife's hair dryer to check it. Failing that you should get an electrician to check it all out.
Good luck.
Sep 01, 2014 | Electrical Supplies
How to test charging system on a 76 850t m.g.
put volt meter on generator mounted on top of motor under gas tank, when engine rev is over1200 rpm on tach, should read above 12 volts,up to 13+. check tension on genny belt, if loose, will not spin genny well enough to make charge
Mar 11, 2014 | Moto Guzzi Motorcycles
Had this on my Honda genny thought it was override switch turned out to be wire off inside cover of the genny connected back up works like a dream.....Try it, it may solve the problem..
Dec 31, 2012 | Coleman Powermate Powermate 5000W...
Have a 67 ironhead. Any reason I can't install a generator from an 83?
nope if it bolts up make sure the wires are red (A) armature (F) field and battery pos + make sure u polarize the genny by making a jumper wire from (A) ON GENNY TO POSITVE ON BATTERY TILL IT SPARKS NO LONGER THEN CHECK VOLTAGE SHOULD PUT OUT 12V TO 14 V WHILE RPM IS 2000
Apr 18, 2012 | 1979 Harley Davidson XLH 1000 Sportster
Kohler boat genny surges
Check fuel supply, carb etc
Feb 05, 2012 | Kohler Electrical Supplies
10 months ago I had my 6 year old Dometic A/C replaced by a friend who bought the new unit directly from Dometic via a Dometic employee. It worked fine the two times I use it this past winter while...
10 months ago? Do have any warranty on this?
As far as adding refrigerant. Yes - you can add some - but you need to fix the leak first, since it will be quite expensive to keep putting refrigerant in. I would first try to get the mfc repair it and if that fails I would call a serviceperson.
note: fixing a leak and re-charging the system is going to take someone 'very' knowledgable of air conditioners.
good luck!
Jun 13, 2011 | Dometic Rooftop RV Air Conditioner
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
Craftmans generator
Snake oil if its a sears (ie likely generac) this oil will be just as good of an investment as this POS genny is
Aug 31, 2008 | Coleman (100076) Compact Refrigerator
Excel 2007: number formatting
Let me give you some basic info first. Information within a cell is discreet. You can add to it...the $ sign as an example...with functions (actual code which equals a program) embedded in Excel or you can type it in.....but you would have to create an actual program to do what you would like to do.
I don't use your version of Excel but I am extremely confident you cannot do what you would like to do. Sorry....Tango.
Feb 08, 2008 | Computers & Internet
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
