Question about Dryers
I cannot get my ceiling fan to work again after the chain broke
shaggyrat
  • 1224 Answers
SOURCE: Hampton Bay Ceiling Fan 476-317
you will have to order this switch direct from hampton bay
or one of there dealers
http://www.eceilingfans.com/switches_-_pull_chain_-_ceilin.html
this is the link needed shows what the pull looks like print out the page match with your wires in fan
this is there home link with phone number for ordering parts
Posted on Jun 08, 2008
SOURCE: Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
Posted on May 09, 2009
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Posted on May 12, 2009
  • 1126 Answers
SOURCE: chain broke off ceiling fan
Is it broken off inside the pull switch? If so, I would recommend replacing the switch. The chain attatchment assembly is riveted onto the electrical part of the switch. It is possible to drill out the rivets to separate the two sides of the assembly to replace the chain, however you would need to use small bolts with nuts to reattatch pieces together after installing new chain. It's a pain in the back side.
(of course all this repair work needs to be completed after removing the fan from its ceiling location and disconnecting the wiring)
Posted on Sep 17, 2009
Testimonial: "thank you for this! Yes, the chain is broken off inside and I can't turn the fan off...but this helps and I'll get it looked at."
  • 57 Answers
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Posted on May 16, 2010
How do I check to see if the motor is bad on my ceiling fan?
You bought the wrong switch. Just because it looks the same on the outside doesn't mean it's the same on the inside(switch). I don't know if you have a bad motor but it is a cheap low-end fan only made for Home Depot!
Apr 28, 2016 | Hampton Bay Dryers
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
Fan chain broke and i want to put it back together
If the chain broke from inside the fan you will need a new switch $6 at any home improvement store and if its just the chain links you can buy a another replacement one. Make sure you tell them which switch is broken, fan or light so you get the right one and how many speeds if its the fan
May 01, 2010 | Hampton Bay 24002 Ceiling Fan
Ceiling Fan Chain Broken Off
You have to kill all power to the fan and start taking it apart till you get to the switch. There's usually just a bottom plate to remove. Sometimes lights. Replace switch and reassemble. If some chain is still connected to the switch you can add chain to it and won't have to replace switch.
Oct 04, 2009 | Dryers
Chain broke off ceiling fan
Sep 17, 2009 | Hampton Bay Dryers
Wire diagram for pull chain on ceiling fan hunter original
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Hampton Bay ceiling fan with pull chains not working
Whether there is a reset switch on this unit or not would depend on the model. If you no longer have the owners manual you should be able to get it from the hampton web site. Many fans have a thermal fuse inline that probably was blown when the bulb broke. The cheaper models do not and then I would guess you burned out the switch.
Feb 07, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Ceiling fan will not turn off
There is 2way switch attached to this chain you need to replaced it.
Jun 04, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
How to replace or repair center fan speed pull chain
the chain goes into the switch and operates a round contact plate. just get a new three speed switch.
Jan 31, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Dryers Logo
22 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
