Question about Pool & Spa
Does a Dream Maker 8003 xspa 4 man Jax have a heating element
2 Suggested Answers
Coastsider
  • 331 Answers
SOURCE: I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Posted on Aug 15, 2012
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker spa at temp outside 40 is heating water till only 80 dont know what to do.
This is common when your Heater element is bad.
The friction of the water moving through the pump typically will raise the water to around 80.
Jan 17, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I received my brand new ez spa today and once I got the water in and pushed test on the gfci the spa came on and so did the jets. I understand that the motor needs to run to heat the water but does the...
Yes, the jets will run anytime the heater is operational. This is neccessary to keep the plumbing from melting, and also to evenly distribute the heated water. Most hot tubs only take 4-5 hours to heat up, but the easy spa takes very long because they use a very small heating element. Usually only 1.5KW.
Jul 26, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
My hot tub will not heat up. The motor is running
sounds like the heating element has gone to the next life,.....you can test it with an ohm tester,....MAKE SURE POWER OFF WHILE WORKING ON IT!!!! but no doubt it just needs a "heating element" cracklin joe
Jan 05, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker hot tub keeps needing to be reset at the plug i have to keep resetting it all the time is there another fuse or something i can do
Your heating element is going to ground and 'leaking' current. The GFCI is picking it up and you will need a new element.
Aug 19, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Ascaso Dream heating element gone - twice
don't have a solution, but i can say the identical thing has happened to me. my heating element has burnt out after only 19 months. i don't know if i should replace it. did you buy a new machine? if so, which one.
thanks
Jun 28, 2009 | Keurig B60 Coffee Maker
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
