Question about Waring Blenders
I have a 6 year old Waring WSB40 immersion stick blender and it is becoming very noisy most of the time and looses strengh when noisy, Is it something that can be repaired
  • 3 Answers
SOURCE: instruction manual for the bamix immersion blender
From the BAMIX.com website
Mayonnaise 1 egg (or 1 egg yolk) 1 teaspoon of lemon juice 1 teaspoon of herb vinegar 1 pinch salt 1 pinch pepper 1 ½ - 2 cups of oil 1 teaspoon of french mustard Put all the ingredients except the oil in a jug (not too large) and blend well with the WHISK. Then add the oil in a thin, steady stream (not drop by drop), processing all the time, until the mayonnaise has reached the required consistency. To achieve perfect results, all ingredients should be at the same temperature.
go back
Posted on Dec 22, 2008
SOURCE: Can't find replacement parts for my Thunderstick Pro blender
I can sell you part of mine. I getting a new one to replace a part for mine.
Posted on Jun 10, 2009
  • 1739 Answers
SOURCE: need new chopper bowl for the immersion blender by Wolfgang Puck
Replacement parts for Wolfgang Puck Immersion Blenders are available here:
http://www.wpcookware.com/categories.asp?cat=26
If you do not see the model number for your product or parts are not shown, suggest you contact their Customer service at 1-800-275-8273 to determine if the required replacement part is available for your model. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sooner but just discovered this site.
Posted on Apr 01, 2011
  • 1739 Answers
SOURCE: BIBC1030 Blender: I won the Wolfgang Puck Immersion Blender/Chopper ...
SOURCE: How do you get the blender coupling driver off the
how do you change the coupler on a waring extreme blender
Posted on Apr 08, 2011
Replacement end coupling
Possibly an appliance parts supplier can help.
Nov 27, 2013 | Waring WSB40 Blender
Immersion blender won't start
I think you need a new one you burn up the motor.
Jan 07, 2013 | Waring Pro SB10 Professional Immersion...
How do open a Waring WSB40 Mixer
Blender not working,Power supply is ok.
Jul 26, 2012 | Waring WSB40 Blender
We have an old Waring Futura 900 blender that leaks at the bottom of the glass around the beater blades. How do you repair? Is there a gasket?
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Aug 09, 2010 | Waring BB180 Work Top Blender
Need new chopper bowl for the immersion blender by Wolfgang Puck
May 02, 2010 | Wolfgang Puck Immersion Blender
Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Blenders Logo
150 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
