Question about Vacuums
Are those new wireless stick vacuums worth buying? I love the idea but, it seems power must be limited or weak without enough suction.
    Scholar:
  • 135 Answers
I retired from fixing battery powered cleaning equipment a few years ago. The problem with wireless is that the batteries don't hold up. They will work fine for a few weeks- then they start to run out of juice after only a few min. On most rechargeables if you don't run them down completely, they only charge to the point you last put it on the charger (It's called battery memory). I personally think the rechargeables are a waist of money, and, when the batteries start to go- are frustrating. Just get an upright, with a side hose. I've got two at home that are over 20 years old. I only had to change the beater bar brush and belt twice in that time. No more than $150 bucks should be your price point for a vacuum used at your own home.
Posted on May 06, 2017
LizDahl
  • 75 Answers
SOURCE: Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
Posted on Jan 28, 2008
chris321918
  • 32 Answers
SOURCE: vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Posted on Jan 19, 2009
ThinkVacuums
  • 144 Answers
SOURCE: mine is a new upright Meile power plus. When I have it
Sounds like you have a clog. There are screws in the back of the vacuum that you can undo and find the clog. If you need assistance or if that doesn't solve the problem.
http://miele.com/locator/locator_new.asp?nav=800&snav=800&tnav=800&oT=7
^this will help you find an authorized Miele repairshop.. you can also call them at (888) 785-2828
Posted on Sep 01, 2009
Testimonial: "The answer was right on. I did find I had a clog in the attachment hose. thankyou"
  • 14 Answers
SOURCE: weak suction on rainbow se vacuum
With years of use, you will collect a layer of "micro dust" on the impeller (the fan part) which reduces the efficiency. A toothbrush and some mild cleaner with gently scrubbing will restore it's power.
The impeller is that parts that spins that you can see when you take the top off to fill the water tank.
Hope this is the answer that you need!
Posted on Nov 15, 2009
SOURCE: My vacuum tools have very weak suction.
There is a foam ring filter in the bottom of the canister that collects the dirt. It screws off of the bottom on the canister. Take outside and shake it out. It fixed our suction problem.
Posted on Apr 03, 2010
Weak suction
if you've changed filters and checked for blockages it may need a new suction fan ,,you can download the diagram off the link below
http://www.ereplacementparts.com/black-and-decker-phv1800-dustbuster-parts-c-4167_8887_8897.html
Mar 13, 2013 | Black & Decker PHV1810 Bagless Handheld...
Uv200 very weak suction
is there a blockage in the inlet pipe ???
Jul 12, 2012 | Black & Decker UV200 Wet/Dry Vacuum
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
Wertheim vacuum cleaner 2000 does not seem to be having enough suction
If you are sure the is no leaks on suction line, please check and clean the filter. The common problem on weak suction vacuum cleaner are leaks and filter clog up.
Regards
Jun 18, 2011 | Vacuums
The performance indicator light will not go out. I have cleaned the bag, filter and hose. there does not seem to be enough suction.
you are clogged somewhere ...
no suction?
performance indicator says no suction?
find and remove the clog.
id be looking in the hose about 4 inches from where the dirt enters the brush but dont limit your looking. The entire system should be checked for a clog. Remove it and you willbe back in business.
I have 'trash picked' more than 100 vacuums this summer, off the curb. 90 were clogged. I cleaned then and turned them into $.
Oct 13, 2009 | Vacuums
My kenmore hida filter vacuum cleaner no longer has the sucking ability it used to have. It is only 4 years old and has worked extremely well up until this week. The motor is functioning well, as is the...
well i've hade one come in a while ago and it didn't have good suction so I looked at the bag it was buljing w/ dirt so I put a new bag in it and it had better sucktion but still not good enough so I cheched the fabrick filter and it was dirty too so I washed it and it had even better sucktion so try the paper filter on the end too and if your vacuum still haves bad sucktion try looking if the hose is clogged buy putting your mouth on the end and blowing through it i recomend whiping the end off befor blowing if hard to blow it is clogged, if clogged i would put something thin like a metal rod or or a stirty stick to push the dirt out i'm sorry if my info didnt work out :D
Jun 12, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Feb 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Little to no suction even with new bag, rug head spits dirt out
Proably a cloged pipe and suction hose>>> take both ends loose and run a broom stick through it..
Let me know if this helps and please give a good raiting
Jan 29, 2009 | Electrolux Guardian Bagged Canister Vacuum
Hi my vacuum (Russell Hobss 2200 bagless HEPA) seems to have just enough ( not loads) of suction til it reaches the cleaning head. the head does not appear to be blocked - but there is then almost no...
Generic problem for all Vacuums
Hi my vacuum (Russell Hobss 2200 Bagless HEPA)
Hi my vacuum (Russell Hobss 2200 Bagless HEPA) seems to have just enough (not loads) of suction till it reaches the cleaning head. The head does not appear to be blocked - but there is then almost no suction at all.
It also makes loads of noise when on- and an even louder noise when turning off.
is it fixable or is it dead?
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Well there seems to be maybe a few problems, the head may be clear, but the hoses could be clogged and or the HEPA filter could be clogged as well – if the hoses and wands are clear and the filter clean you may look @ a motor replacement depending on the cost or to buy a new vacuum and in some instances you can trade in your old vacuum for a new one – but check it fist from the suction head thru the hoses, wands and filters, B4 you decide to purchase a new one or to replace the old motor with a new one depending on cost. A rule to live by – the item cost more to repair that to replace – replace the item, if the repair cost (as an example) say $50.00 to $60.00 and to buy a new one would cost $100.00 – buy a new one.
Don – The Vac Man
Apr 21, 2008 | Vacuums
Nov 04, 2007 | Electrolux EL7055A Bagless Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
