Question about The Video Cameras
MY CAMCORDER IS NOT GETTING POWER EVEN PLUGGED INTO THE AS POWER
  • The Master
  • 5,412 Answers
1) Please don't shout, it is considered impolite.
2) We cannot help unless you give us full details of the camcorder make and model.
Posted on Apr 27, 2017
How to fix Sony HVR-HD1000U camcorder if it is not charging
hi,
the fault should be in side the cam, start test from the charger connecting socket, measure the power in the mother board, if any of the fusible resistor or the regulator SMD found faulty, must replace.
Dec 01, 2015 | Sony HVR-HD1000U Camcorder
My camera turns on when I plug in the power cord even if the power button is set to off. It does not work with a battery, only the power cord.
Hi, That sounds normal. Most camcorders will come on when plugged in. If you think there is still a problem go to a camera repair. Good luck.
Sep 15, 2011 | JVC Everio GZ-MG77 Camcorder
The camcorder won't turn off. I even take battery out then replace it it is still on
Make sure it is not plugged into your computer. If you have the camcorder plugged in via your USB connection, then your camcorder is being powered by your computer.
Unplug everything from your camcorder and then try to turn it off or take the battery out.
Aug 22, 2010 | Samsung SC-DC173 DVD Camcorder
My JVC GRD225 camcorder will not power on or charge even when the mains power cable is plugged in. No life what-so-ever.
Well all i like to say that first of all you can try changing the battery of your camcorder, this is the most common problem of not charging error..........
Good Luck!!
Thanks for using FixYa!!
Jul 27, 2010 | JVC GR-D225 Mini DV Digital Camcorder
I have a Canon FS100 Digital Video Camcorder. I am attempting to download some video on to my iMac, but then I select "Connect To Camera" I get the message "No Camera Was Found". I have the camera plugged...
The computer is no longer detecting the camcorder for several reasons. It could be the ports on the computer, it could be the cable that you're using to connect the camcorder to the iMac, or it could be the camcorder itself.
Try connecting the camcorder into different USB or FireWire port of the iMac.
Try using different cable.
Try connecting the camcorder into different computer to test the device.
If all else fails, power cycle the camcorder by turning it off and remove the battery for about 10 minutes. Then turn it back on. Otherwise, contact the manufacturer for second opinion.
Hope these helps and have a great day!
Aug 12, 2009 | Canon FS100 Flash Media Camcorder
My Canon FS200 DVC isn't transferring files
Hi mate, I had same problem as you, took the cam into store and teh guy helped me out.
Make sure you get the recharger for the camcorder, then plug it into teh camcorder and also to the wall power when you are uploading the files. It can needs an extra power boost to get the files onto your computer.
- so plug in your camcorder to computer
- also plug in the battery recharger cord to the camcorder
Should work fine!!
Jul 13, 2009 | Canon FS100 Flash Media Camcorder
CANON MINI DV
It probably has a defective power supply and will need to be serviced by a professional.
Jul 26, 2008 | Canon ZR800 Mini DV Digital Camcorder
Camcorder keeps shutting off when plugged in - how to disable power saver?
slinkystairs,
Simply remove the tape from the camcorder, and it should stay on. If you have a tape in the camera, the auto-shutoff is activated assuming you wish to record to the tape, regardless of the firewire connection to your PC.
Dec 29, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
No power
One of the fuses is blown on the main pcb, needs to go in for repair if you need to get the tape out i can maybe take some pics at work and post them for you to see sorry.
Nov 19, 2007 | Canon Optura 60 Mini DV Digital Camcorder
Video Cameras Logo
50 people viewed this question
Top The Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Glenn Smart
Glenn Smart
Are you a The Video Camera Expert? Answer questions, earn points and help others
