Question about Power Computers & Internet
WONT TURN ON
BRAND NEW BATTERY. EVEN PLUGGED INTO THE AC POWER NOT GETTING POWER
  • Power Master
  • 3,828 Answers
Faulty AC charger power source
or typical mother board problem not recognizing battery is there
Posted on Apr 27, 2017
  • Tamera Cain-Hines
    Tamera Cain-Hines Apr 27, 2017
    This is a camcorder and when It was given to me I charged the battery and tried to turn it on and it wouldn't. So I thought I needed a new battery. nope. I got a new battery and the charger said charging for about an hour then the charge light went off and I still cant turn it on. So, I tried the AC plug...No luck there either.
  • magna buff Apr 27, 2017
    added an exploded image of a cam corder on first response
    if it inst a broken on off switch
    they have an internal digital circuit board
    capacitors resistors and chips
    (mother board )
    whole lot could be checked out with an oscilloscope to find the fault
    if an old camcorder would say you will be told its not worth fixing
My PSK2LU-02J00D wont power on, checked battery and power supply both are working
The laptop doesn't turn on even if it is plugged in with the AC adapter? Also, what was the last thing you did prior to the computer no longer turning on?
When you plug in the computer with the AC adapter, battery light on the laptop turn on?
Jul 02, 2014 | Toshiba L655D-S5164 Notebook PC -...
No Power
Your laptop's power jack may be broken, which is why your laptop doesn't charge your battery at all, which is why it won't turn on now. I would take a look to make sure that the power supply is good, the battery is good, and then see if the power LED is even coming on when you plug the laptop to a power source.
Apr 10, 2013 | Gateway Computers & Internet
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
Advent modena m200 will not turn on or charge.
Connect the AC power adapter to the laptop and confirm that the AC power indicator is on (I wish you stated the brand of laptop). If the AC power indicator is not on, try and get a working AC power adapter for your laptop and connect it to your laptop.
With the AC power adapter connected, you can power on your laptop. If the laptop powers on from the OS you can see if the Battery is charging or not.
If the laptop does not power with the AC power adapter connected, then the power port of the laptop is bad.
However, if all these are okay and the battery still does not charge, the battery is faulty and will need to be replaced.
May 15, 2012 | Advent Computers & Internet
Advent t1600 wont start, it used to start with the mains plugged in was told it was the battery but wont even power up in mains mode now
First try using a different ac adapter/power cord.If after trying that it won't power up it only leaves the power board where the power button is located may be bad or the power jack where the ac adapter/power cord plugs into the laptop may be bad.Alot of the time when the ac adapter/power cord gets weak or stops working at all will cause it to not charge or not turn on even plugged in.
Oct 27, 2011 | Advent Netbook
Will the laptop power up with a bad battery
You dont need battery to power up if plugged into mains charger.
Do any lights com on at all??
Dec 30, 2009 | Compaq Armada M700 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
AC Power and Battery Problem.....
Sounds like the battery or possibly the charging circits themselves are the problem. Can you try turning on the laptop with just the power cord in and no battery?
Aug 20, 2008 | Compaq NC8000 Notebook
Turning on problems
plug ac in...turn on pc...wait for boot then press and hold power switch(on pc)down until you hear shut down .restart.
if no luck remove battery and do the same precedure(without battery )
if/when pc startup and is in windows replace battery anytime.
Apr 10, 2008 | Toshiba Satellite A25-S207 Notebook
Computers & Internet Logo
Top Power Computers & Internet Experts
waruna
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
