Question about The Computers & Internet
To shut that off hit the Express Thaw features
2 Suggested Answers
SOURCE: Refrigerator and Freezer not cooling....
  1. my kenmore side by side Model #465825 Refrigerator doesn't cool or and ice maker is'nt making ice.
Posted on Dec 09, 2008
I have a GE Profile Artica, This am the unit stopped running and the adjust temperature displays were both blank. The letters hrs appear in the turbo cool display. I unplugged the unit for 1 hour and...
The "HRS" indicator is referring to hours and is related to the Quick Thaw or Express Thaw mode. If the Quick Thaw or Express Thaw feature is turned off then the "HRS" should disappear. However, it this is not the case most likely you will need to replace the main control board.
Dec 31, 2017 | Refrigerators
My GE Profile side by side refrigerator keeps going to express thaw mode and temp is way out of range. Any ideas on the problem?
Nov 24, 2010 | GE Profile PSS26NGS Side by Side...
The freezer & refrigerator will either turn on & cool and or freeze but won't shut off. Or they will not come on at all and get warm or thaw.
The newest defrost feature in modern fridges is the electronic adaptive defrost control board. *Maytag has one version, to put this adaptive defrost style of fridge into defrost, short with a small screwdriver between L1 and test on the adaptive defrost board, wait 3 seconds and you should hear a "click" noise from the relay and the fridge will shut off and go through a defrost cycle.
Nov 18, 2010 | Maytag Refrigerators
Express Thaw comes on when refrigerator door is closed
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
Feb 11, 2010 | GE Refrigerators
My express thaw won't turn off
You have a bad main control board problem . Stuff a shelf in the refrigerator section with crumpled up newspaper and leave running ( the ink in the paper absorbes odor . Takes several days to eliminate .
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice making feature not working
Most likely the ice fill tube has frozen up and will not allow the water to fill the ice maker. You will need to remove the icemaker (three small screws) and take a hair dryer and thaw out the fill tube. You can use a bent up coat hanger to reach in and remove some of the ice that is formed up in the tube as you thaw out the ice. Also check the Icemaker's actuator arm. This sometimes is hung up by a small piece of ice that hasn't dropped causing the Icemaker to shut off. (This is the first thing to check )
Apr 27, 2009 | Viking Professional VCBB363 Bottom Freezer...
Icemaker won't stop making ice
there should be a saftey shut off bar or something in there to shut the ice maker down, look inside and see if there is a bar, or holes where a bar should be installed, if there is a bar, the the auto shut feature is not working you will need to replace it if thats the case, best of luck, hope that helped
Jan 18, 2009 | LG LFX25960ST Stainless Steel French Door...
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
How may I set the vg 2 on my express 795?
Entering Selectable Features Mode
1. With the unit OFF, press and hold the CITY button then press
the PWR/VOL button. The amber X LED will illuminate and a short
“beep” will sound.
2. Immediately after the “beep”, digit #1 will appear and indicate
the status of the sws™ Selectable Feature. To select digit #2 (VG-2
Guard®), press the CITY button again. To select digit #3 (sws™
Voice), press the CITY button a third time and to select digit #4
(Digital Voice prompts for Radar/Laser/VG-2 Guard®) press the
CITY button once again. Use the CITY button to select one of the
four digits.
3. If the selected digit is solid, feature is ON, but may be canceled
by pressing the AUDIO button. Two “beeps” and the flashing digit
will confirm feature is OFF.
4. If the selected digit is flashing, the feature is OFF, but may be
activated by pressing the AUDIO button. A single “beep” and
solid illumination will confirm the feature is ON.
5. Press the PWR/VOL button to retain your new settings for Selectable
Features. Two “beeps” will confirm that you have exited from
Selectable Features Mode and your unit will be ON.
Dec 09, 2007 | Express 795 Radar Detector
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
