Question about In Microwave Ovens
Food fire food overcooked and smoked in microwave bad odor and now the food is gone but the smoke odor is left. how do I get rid of the smell now. microwave itself is unharmed thank you, hank
  • In Master
  • 5,326 Answers
You should be able to get a cleaner spray suitable for use in microwaves. Give the insides a good spray and a good clean, it should take it away. Make certain there is no burnt deposits anywhere.
Posted on May 12, 2017
  • 9098 Answers
SOURCE: Panasonic NN-T694SF smoke, shuts itself off
In most cases, this is a problem with the inverter or a bad transfotmer.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
Posted on Oct 22, 2007
  • 52 Answers
SOURCE: burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Posted on Aug 19, 2008
  • 9098 Answers
SOURCE: Smoking microwave
It could be the fan motor, a component on the circuit board that drives the fan (triac) , the magnetron, high voltage transformer, etc.
It will need to be diagnosed. Smoke is always a bad sign, but not necessarily expensive for a do-it-yourselfer.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 02, 2008
  • 108 Answers
SOURCE: Did I blow it up????
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Posted on Nov 16, 2008
SOURCE: How can I clean the black smoke residue from inside microwave
use a scouring pad.
Posted on Mar 14, 2009
How to get rid of odor in microwave?
Hi James,
You could give Vanilla essence a try works a treat.
Good luck
Apr 26, 2014 | Microwave Ovens
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
I placed food in the microwave over to heat for 19 seconds, when it was finished I smelled smoke coming from the oven. The food was fine. I unpluged the oven. I tried it a couple of days later, it...
the smoke probably came from the heated food. try using it next time with different kind of foods and also try it to the same kind of food that produces smoke but observe carefully what will happen.
Dec 29, 2010 | Emerson Microwave Ovens
Food left in the oven has left a smell even after thorough cleaning.what action should i take
Have you tried putting a microwaveable bowl with a mixture of water ,vinegar and some slices of lemons or oranges in your micro for about 2 minutes. It should help eliminate the bad odors and leave your microwave smelling freah and clean.
Nov 10, 2010 | Panasonic NN-H965 Microwave Oven
Left fyring pan in oven during cleaning cycle
hi dr68,
The service techs at servepro fire/water damage cleanup and restoration might have a few free suggestions, they deal with smoke damage/residual odor issues every day.
Servpro Industries, Inc.
801 Industrial Boulevard
Gallatin, TN 37066
Phone: (615) 451-0200
Fax: (615) 451-0291
Oct 16, 2008 | Sharp R-1610 Microwave Oven
Odor of burned popcorn!!
The smoke has permeated the works, so a more aggressive cleaning will be needed.
There are many good suggestions for cleaning and deodorizing microwaves here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Jenn-Air JMV8208AAS Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
