Defaul pin forg0tten it - Computers & Internet
Have taken over this system and need to reset user password as we need to programme the system
There is a small hole somewhere on the back (usually). Get a needle or a staple pin it down to push the button inside the hole. Hold the button 30 seconds to reset the ruter. After the reset you'll have to set it again as it is reset to its defaul user settings (user, password etc). Be sure that you have all the necessary info - IP adress to set it up and default user and password for your ruter (this info is in the manual, a Cd or a sticher on the bottom side of the ruter)
Aug 05, 2010 | Computers & Internet
Dwl-2100ap will not update firmware
1) Reset do default the device (rear reset button)
2) Set your PC a IP like 192.168.0.xxx (defaul IP address for DWL-2100 AP is 192.168.0.50)
3) Connecto via browser to 192.168.0.50, defaul login
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and selectInternet Protocol (TCP/IP), click properties, click set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
If this information can help you, please rate me ;)
Aug 31, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Comm. error
nothing hapen with your printer,because poor telephone line. Turn off and on,if this masseger still display you shoud "reset factory defaul" by press enter,right -hand arrow untill the display control appear"srevice" press enter again- choose "reset factory defaul" and double click enter. your printer will be reset
Jul 22, 2009 | HP LaserJet 3050 All-In-One Printer
I cant instal xp in thoshoba L40
u can't cause the defaul O/S is Vista and Xp is lower so u can't download xp try to install either vista or windows 7
Jun 09, 2009 | Intel Frontier Design Dakota 24-Bit PCI...
I have a cannon print mf6500 and i have a littleproblem , i want to reset it to have the defaul setting .
Check the manual:
Or this link:
http://static.compusa.com/pdf/canon-imageCLASS-MF6500-Series-ScannerDriverGuide.pdf
Jan 23, 2009 | Office Equipment & Supplies
NO VIDEO ON DELL INSPIRON 1501!!! PLS HELP ME!!!
ok
when u power up the paltop press F8 key then go to last known good configuratuion if probelm remains same then chosse safe mode then remove your network driver from it.
also try to rest your defauls sdetting in bios .
when u power yup the laptop press del or F2 or F5 to F12 try this key one by one.
then go to load defauls settitngs then save that settings.
also check in enable vga mode when u press F8 key at power up.go to enable vga mode tthen settings of disaply porperties.800*600 or 1024 *768.
Nov 10, 2008 | Computers & Internet
Secret code of nokia phones
defaul code is 12345, if it doesnt work, post your imei and i will generate one for you
May 16, 2008 | Cell Phones
Partition Magic Software Error #983
Re: Error 983 while using Partition Magic Error 983: "Too many errors found, process halted"
http://service1.symantec.com/SUPPOR...gic&svy=&csm=no
Utilize the following maintenance programs before using Partition Magic:
Description of the Disk Cleanup Tool in Windows XP
http://support.microsoft.com/defaul...2&Product=winxp
How to Perform Disk Error Checking in Windows XP
http://support.microsoft.com/defaul...5&Product=winxp
HOW TO: Analyze and Defragment a Disk in Windows XP
http://support.microsoft.com/defaul...1&Product=winxp
Mar 31, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
