Question about Refrigerators
On door display instead of freezer saying 0 and referigerator display saying 36 degrees. the referogeratpr display says FF. HELP!!!!
  • 1462 Answers
SOURCE: got an american whirlpool fridge
may be a indication only but on many fridge-freezers, 2 flashing lines ,means power interuption
Posted on Sep 17, 2008
docjohn174
  • 943 Answers
SOURCE: freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Posted on Oct 17, 2008
duby1990
  • 370 Answers
SOURCE: Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: PLHS69EGSS1 Freezer not cooling properly but Frig is OK
try to check the defrost thermistor and also make sure that the unit is working with the right FULL LOAD AMPERAGE by looking this we will know if it has exact refrigerant in the system.
Posted on May 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Why is the refrigerator not cold, but cool?
If freezer is working & refri.not check damper vent could be frozen or closed
May 07, 2015 | Refrigerators
Recommended temp settings for freezer and fridge
The ideal freezer temperature is 0 to 5 degrees and the fridge section from 36 to 40 degrees. However, you will get more accurate responses if you leave the model number of your exact unit.
Jul 15, 2013 | Computers & Internet
The freezer says FF after it kept beeping. I unplugged it and plugged it back in and it hasn't helped. What else can I do? The temp was 25 degrees
Google your problem with the mfr. and the code ff and it will give you solutions. Do this if you don't have a manual or call dealer.
Feb 09, 2013 | Freezers
The temperature display is reading 0 degrees
Zero degrees F is the normal operating temperature for a freezer. The compressor should not come on until the time is above that.
Apr 26, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My referigerator is running coolabout 45 degrees.freezer/wmer sometimes. thefreezer is not gttig real cold. hope you can give a idea of what may be wrong
You may have a sealing issue with the freezer door. If the rubber gasket around the edge of the freezer door is not sealing properly it will cause the freezer to be warmer. You may not easily notice the seal problem so check it all around the four edges of the freezer. hope this helps :)
Dec 12, 2009 | Whirlpool Refrigerators
What temp.should the ref. and freezer be
referigerator appx 36 degrees freezer -5 to -10
Sep 29, 2009 | Samsung RS2534 Side by Side Refrigerator
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
Frigidaire Upright freezer with Beeping Display
the thermistor is most likely bad. you would have to take an ohm reading of the thermistor and check the tech sheet to see if it is in range. The thermistor is $50 to $75 part.
Jun 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
