Question about Refrigerators
DOOR SAYS FF INSTEAD OF 36 DEGREES
THE FREEZER DIGITAL SAYS "0" BUT REFRIFERATOR DISPLAY SAYS "FF" WHAT DOES HTIS MEAN
SOURCE: frost free fridge/freezer
that is an error code call manuf. for solution
Posted on Dec 07, 2007
  • 1462 Answers
SOURCE: got an american whirlpool fridge
may be a indication only but on many fridge-freezers, 2 flashing lines ,means power interuption
Posted on Sep 17, 2008
docjohn174
  • 943 Answers
SOURCE: freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Posted on Oct 17, 2008
  • 3 Answers
SOURCE: PLHS69EGSS1 Freezer not cooling properly but Frig is OK
try to check the defrost thermistor and also make sure that the unit is working with the right FULL LOAD AMPERAGE by looking this we will know if it has exact refrigerant in the system.
Posted on May 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2010
How to lower freezer temperature
Not sure what you mean by the freezer too cold? The freezer section should be at or below 0 degrees C or 32 degree F. if its working properly. If the FF section is too warm and your temp control door or vent is at max cold either the vent is not moving (stuck in the closed position) or the fan in the freezer is not working.
Nov 10, 2014 | Frigidaire Refrigerators
Recommended temp settings for freezer and fridge
The ideal freezer temperature is 0 to 5 degrees and the fridge section from 36 to 40 degrees. However, you will get more accurate responses if you leave the model number of your exact unit.
Jul 15, 2013 | Computers & Internet
Just had the thermistors replaced in the frigde freezer the fan is working now and the freezer is - 22 but the fridge is at 14 degrees.
Where are you getting these temps from? If your unit is in Celsius mode, that would mean fridge is 57.2 degrees and Freezer would be -7.6 degrees. Without a model number I am unable to see the style of controls you have. Double check all settings are in the middle, meaning if you have a digital display, temp @ 0-36, if you have dials make sure they are set to the middle ie..(a-e then set at c, 1-9 set at 5).
I hope this helps...
Jul 23, 2011 | Refrigerators
The display is showing ER FF WHAT DOES THAT MEAN
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Jan 27, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
The temperature display is reading 0 degrees
Zero degrees F is the normal operating temperature for a freezer. The compressor should not come on until the time is above that.
Apr 26, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
My Chestfreezer is displaying FF
I believe the FF would mean a thermistor has an open circuit . If so then the sensor would need to be replaced .You can ohm the sensor and at room temp it should be around 1100 ohms.
Always disconnect power before attempting to repair any electrical appliance
Oct 21, 2017 | Freezers
Frigidaire Upright freezer with Beeping Display
the thermistor is most likely bad. you would have to take an ohm reading of the thermistor and check the tech sheet to see if it is in range. The thermistor is $50 to $75 part.
Jun 09, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
