I am currently charged $90.57 as from 21.5.17 it will be $75 is this correct?
When charging, it all night it still said,low battery
check connections and wiring on and around battery if corrosion or damage - a fully charged batteries current will not flow correctly --check that charger is working correctly--have battery tested most auto stores offer this service for free more than likely battery gone bad and not holding a charge
May 21, 2016 | Cars & Trucks
My portable charger wont stay on. How do you make it stay on to charge the phone?
If you're using the charger supplied with the phone, it should either work or not. If it doesn't; either the phone battery, charger or both require replacement.
If the battery is "good" and you are using a "3rd party" (non-original equipment) charger, you may not have one that is incapable of providing the correct voltage, charge current or both. If the charger can not provide adequate charge current or voltage, it is very possible that the charger is shutting off due to excessive heat. Once sufficiently cooled, it charges again.
Make sure that you've got the correct charger - or one that is designed to charge the type battery in your phone at the correct voltage and current rates.
Apr 08, 2015 | Cameras
My kindle fire does not charge.
If you are truing to charge with a USB post then switch to a wall wart. There is often not enough voltage to charge from USB.
Feb 04, 2015 | Amazon Kindle Fire HD
How to charge a jump starter
with the correct charger. Look for the voltage (Volts)and Current(Amps) Charge it with a charger with the same parameters.
Mar 12, 2014 | ump N Carry JNC 4000 12 Volt 18Ah...
You can if your charger is universal, if not, by the correct charger for that voltage. The device itself wont matter what voltage is being used as the charger will convert the input current of 240V to whatever the phone is rated at (maybe 9VDC?)
A small electronics store will be able to sell youa charger if yours doesnt suit
Jun 01, 2013 | Cell Phones
What is the function of rectifier? And how will I know if it is broken already
The rectifier convers AC current to DC current by blocking the wrong polarity of charge from the altenator allowing the correct polarity charge to enter the battery and run the electrical stuff on your bike. If the rectifier or Diode Pack fails, you will not be able to charge your battery and if it is short circuit will flatten the battery very quickly. There should be some form of regulator after the rectifier that stops the battery from being over charged.
Hope this explains it for you.
Dec 31, 2010 | Sym Husky 125 Motorcycles
How do you know if the stator is bad on a motorcycle i changed the coil to the spark plug still no spark
Check the ac current coming from the stator leading to the regulator rectifier, it's AC current so set your multimeter correctly and be careful, you should see current going to the R/R if not then it's possible it's bad. Or the R/R may not be putting out charging DC volts to the battery to keep it charged.
Apr 07, 2010 | 1980 Honda GL 1100 Gold Wing
Battery not charging
If the plug is not using correct current in correct location, ie plugged in backwards yes it will not charge unit properly.
Feb 09, 2009 | Dell Inspiron 2200 Notebook
Charging on AC
The Charging Voltage Will depend On Your Countrys Existing Supply Voltage. If Your Standard Electrical Current ( In Home ) Is 110v Then You Would Use This.
******* Please Note:- MP3 And MP4 Players, only usually charge at a low current voltage Between 5-12 Volts.
Always ensure That You Have The Correct Adapter/Charging Lead For Your Appliance****
Failure To heed This Advice, Could Lead To Shock Or Fatality.
If you are In Any Doubt, Connect The Device To a PC Or Laptop With A USB Connecting Cable. This Will also Charge The device, as well as Being Able to transfer Data.
Mike @ Compurepair.
Feb 28, 2008 | SanDisk Sansa e250 MP3 Player
How to find replacement adapter for GR-D70AS
Order the original adapter from JVC. The adapter supplies the correct current requirements to operate the battery charge circuit. JVC's web site is JVC.COM. The correct charger will provide up to 1.5 amperes of current for the charge circuit at approx. 11 volts DC. Good Luck Joe Weibel Custom Electronics (
Feb 10, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
