Trying to find out the manufacturer of an LP gas furnace.
No identifying nomenclature on or in it. I was told it is a York E1RCO24506 12 SEER FURNACEQucatro #GFCD5AO54NHR3 54.000 BTU... CAN'T SEEM TO FIND ANY INFO OR PICS
  • 923 Answers
Manual for model C7BAM03648C-C
According to the web, the model C7BAM03648CC is a Westinghouse refrigeration unit. Are you sure you didn't get the number from the top portion?
C7BAM Cased Vertical Coil
• R410 refrigerant-non-ozone depleting
• All aluminum micro-channel coil eliminates formicary corrosion
• Piston metering for all 13 SEER matchups
• Field installed TXV accessory for 14 SEER matchups
Recent Intertherm furnaces have "M" or "CMF" numbers.
Either way, you will probably have to contact a local dealer because their website is useless.
Intertherm Gas Furnaces
Mar 19, 2015 | Intertherm 56000 Btu Gas Furnace
My gas pack won't light
First, the thermostat white wire is the wire that initiates the furnace to start. When you select heat on your thermostat the tech should get a 24-28 volts between the white wire and common on the thermostat wire in the furnace. If you do not get the required voltage, there is a break in the wire from the furnace to the thermostat that needs to be tracked down and eliminated.
Feb 27, 2014 | Goodman Manufacturing Goodman...
Installing Rheem gas furnace, where is the pressure switch and how do i turn it on/off?
Can you be more specific about which switch, what the problem is and what your trying to do? Thank you.
Nov 23, 2013 | Rheem Prestige Series 3.0 ton 16 SEER...
Why does furnace heat cut back?
You might try checking your return filter. The new filters (pleated 3 month, ie real expensive ones) cut back your air flow 35% from the amount the regular 30 throw away allow. When air flow reduces the temperatur from furnace increases and can cause inadvertant high temperature limits to trip. If you are using a clean return filter, next you need to physically observe the air inlet side of your cooling coil to see if it is blocking air flow due to being dirty. If you have trouble with seeing the inlet, you might need to get a professional to take the air handler apart.
Oct 29, 2012 | Goodman Manufacturing...
I just replaced a thermostat on a york furnace model gy9s100c16up11h. During the process i connected the red and white wire and the unit came on after making the connections it will not come on even if I jump the red and white wires without the thermostat. Thanks Dan
Jun 10, 2009 | Heating & Cooling
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
