Question about Numark PT01 Turntable
EZ Audio Converter does not export files to iTunes
The ttUSB turntable works fine, I can hear the music while recording, and everything works fine, including "step 5: export to iTunes" -- the green bar moves to the end, and I am asked if I want to record more or not.
But -- the files does simply not show up in iTunes. And does not seem to be anywhere in the computer.
Using Mac OS 10.4.11 and EX Audio Converter 3.1 (0).
Any suggestions would be welcome. The vinyls are waiting :)
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
Posted on Aug 09, 2009
  • darlin1937 Oct 14, 2010
    i hope u can help me. I used ion tape express usb portable casette converter, appeared all was going well, except when it opened itunes, nothing was there, I did explore the temp files and sure enough there was :temp0.wav
    I tried to do your suggestion (itunes file...add file........did nothing).
    Now what to do ? I had read this was such a simple thing...now it is a nightmare
    I can use any help i can find
    thank u
  • Dot Van Der Vyver Aug 26, 2013
    i agree with you. seems like they manufactured the turntable without making sure it works with Itunes. it is so frustrating!!!
Hi
I have just come through the real frustrations of having EZ Converter seemingly not working as it did before I updated to the latest version of iTunes and EZ as well as updating my iMac to OS X Mavericks. I have an iTunes collection of nearly 16,000 tracks and have read about the issues involved in trying to back this up if you try to go back to an earlier version of iTunes plus the other problems which might occur with the operating system so it would require to be backed up, apparently another long, long and risky process. I have struggled to find an answer without all the backing up. Here is what I have come up with. I may sound a bit longwinded but I have beens surprised at how quickly, after a few times, I can export a vinyl album into iTunes. I am using a basic ION deck. Here is my solution. Hope it helps.
Open iTunes
Open EZ Converter
Using EZ record one side of an album with automatic track split
Select Next in EZ and go to Step 4;Tag your tracks
Just type in the artist and album names (not even sure if this is necessary), leave the track names empty
Select Next in EZ to export the tracks to iTunes. Looking at the green track exporting line you may appear to have exported an "extra" track. Don't know why this happens. If it appears the extra track, always the last one, lasts only a few seconds and can be discarded later.
When recording is complete the EZ dialogue box appears asking if you want to make another recording. Select No and close the dialogue box and then select Yes when asked if you want to quit EZ.
Go into iTunes and select "All artists' Scroll down till you find the exported tracks which will appear as "Unknown artist" so should be with the "U" artists in your library. Each exported track appears like a separate album and track . The album and track have the format e.g. EZACTmpFile.1
Now take each "Unknown Artist" in turn. Select/highlight the track e.g. EZACTmpFile.1.
Go to the iTunes menu bar and select File and then 'Get info'.
The info box for EZACTmpFile.1 opens. Select "info" from the options. The info box opens with the file name EZACTmpFile.1 highlighted in the 'Name' box. Delete this name and type in the name of the album track. Now complete the Artist/Album artist /Album boxes (and date if you want it. (Date has to be entered for only one track on an album). Click OK and you should have the album and the first track listed in the correct place in your iTunes library.
Repeat the process for all the "Unknown Artists" you have i.e. one for each track on the album you have exported. Drag any few seconds long "extra" track into the trash at this stage.
This sounds quite a long process but after a few tries it becomes quite mechanical and does not take long to export a full vinyl album.
I am relieved it works and can now get on with completing the export of my vinyl albums into iTunes.
Hope this is helpful and works for you.
Posted on Jan 14, 2014
  • 3 Answers
Not solveable for macintosh
i'm im os 104 as well...tried converting .wav files with other converter with no luck
the original wav file was gemnerated by numark EZ converter
nothing is working
Posted on Nov 22, 2009
Had the same problem, but I finally found a solution.
First make sure iTunes can be opened after installation, even if it needs an Ok because it is in the compatibility modus. May be necessary to clean your reigistry on the PC first (was my experience)
When recordings are to be exported from EZ Converter in step 5 to iTunes, you may not see the window that says that iTunes is in the compatibility modus, because it is hidden behind the EZ Converter window. Move the upper window so that you can click OK for opening iTunes. Preferably, iTunes must be opened before you start exporting.
Posted on Apr 30, 2010
Ok, I'm on a PC with iTunes. I used Audacity to convert my EZ Conversion .wav tracks that I just imported to MP3, You load the .wav files in Audacity, then Export them as MP3, add the track data, names and such, and then did a simple Add Folder in iTunes. THAT finally worked - NOTHING else has even remotely worked with iTunes, NOTHING else will import a .wav from EZ Converter into iTunes that I have tried. I have tried every solution posted and something always doesn't follow along the way the user has explained. Try Audacity, Export and then load into iTunes!
Posted on Feb 15, 2015
It's all about having the winning combination of software installed.
After much hair pulling.. this will work!
Mac OS 10.4.11 iTunes 9.2.1 Quicktime 7.6.4 EZ Converter 7.5
This will end all Mac Frustrations.
Posted on Mar 04, 2011
Help I'm using MAC 10.4.11 and EZ 4.0 and I cannot find the converted file. Ideas?
Posted on Jun 24, 2010
Uugh. I recorded 3 full albums yesterday now today it won't capture anything. Same apparent issue. Sound comes through. Input on Mac is USB (and shows volume bars). iTunes open before I record. Still, I get super quick 'green bars' as it 'saves' and then in iTunes, it says time is "not available" ... nothing recorded.
Posted on May 23, 2010
  • stephenfurlo Aug 24, 2010
    I have had to use the Audacity program to get files on to iTunes. When I used EZ Audio, the files appeared but as EZfiles, not the track info, and often these were blank. Audacity is fine, but time consuming has you have to manually split the tracks when using a Mac and name them individually in iTunes - unless anyone else has found a way to label during recording.
I don't know if I am just lucky, but I am using Mac Snow Leopard, ION TTUSB05 and EZ Audio Converter 3 and everything is working perfectly.
Posted on Dec 27, 2009
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
1-I'm recorded my music 10-track on step 3 on EZ Vinyl Converter. 2-On step 5 export recording to iTunes take tolong to complete. 3-I'm access iTunes Music library. I see only 3 music track. 4-Can you...
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
Nov 29, 2010 | ION Audio TTUSB10 Turntable
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
I cannot find the music exported by EZ audio converter
music files converted by ez converter cannot be find in i tunes library because of the incompatibilty of codecs of ez converter and i tunes.try the converters that are compatible with i tunes.
keep updated.thanks and plse do rate this solution.
Jun 18, 2009 | ION Audio iTTUSB Turntable
Won't Export to iTunes
it is not compatible with itunes 9 call numark and complain
May 29, 2009 | Numark PT01 Turntable
EZ Vinyl Converter produces file that doesn't work
Try
Control panel
-Sounds - click on Speech and Audio Devices -
Click onSounds and Audio Devices. or if your in classic view -double click.
Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
Jan 12, 2009 | Televison & Video
Playback Problem
They should be recording in mp3.  Then converted into ITunes using AAC.  Itunes will play MP3 format from the turntable.  The best thing to do is to record in that format, then test the files before converting them.  That way you can find out if the problem is with Itunes conversion or the turntable.
Oct 06, 2008 | Numark ttUSB Turntable
Converting to itunes
Have you recently upgraded any software (iTunes, Windows, etc)
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 05, 2008 | Numark ttUSB Turntable
Numark PT01 Turntable Logo
10,068 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
