I have a $100 jf 27772600 is it more - Computers & Internet
I want to add a simple switched -6dB pad to the Live Wire Solutions PDI passive DI box input connector. Input source is line level at 100 ohm Joyo JF-317 Space Verb. Suggested circuit and parts?
Your answer is in the link provided below. The chart shown is for a 50 ohm circuit but in the paragraph below the chart they address other characteristic impedences and describe the z factor and how to compute.
Mar 23, 2017 | Live Wire Music
TE 8000F. How can I reset my tills?
Press JF button while the key is on off . Now turn your key down to PGM while you are still pressing JF. then after releasing JF press sub/total
Feb 01, 2016 | Retail Supplies
How do we replace battery for a JF-100MS calculator?
I couldn't find the manual for your JF-100MS but I have a Casio FX series calculator that, like yours, is solar + battery backup. On the back of the calculator there should be a small door or coverplate with a tiny screw. If you remove the screw the cover should come off and you can then access the button cell battery for replacement.
Jul 29, 2014 | Casio JF-100MS Desktop Calculator with...
How do i set the euro conversion rate on my casio jf-120ter caclulcator
Already answered here:
Mar 23, 2010 | Casio JF-100TE Calculator
Steering is sloppy on my 79 f-100. is there an adjustment nut on the steering box?
Hey jf,
Check your steering linkage components. Ball joints / tie rod ends should be stiff but movable. If they move freely or loosely, that movement is allowing the wheels to follow every dip in the road even if you're holding the steering rock steady.
Jul 28, 2009 | Ford F-100 Cars & Trucks
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Jan 15, 2008 | Casio JF-100TE Calculator
Casio jf-120er euro rate set
Press AS
Hold Down RATE SET (%) for about 2 second and the correnty rate appears on the display
Imput the conversion rate and the press rate set (%) to store it in memory.
Best regards
Dec 10, 2007 | Office Equipment & Supplies
Calculating percentages
Type 100 x 20%, and then hit the minus button
Dec 05, 2007 | Casio Office Equipment & Supplies
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
