Question about Cell Phones
Fold N Gold 350 It will stop and you have to power off and then on again to get it to go a short distance.
We just go it used and it has what looks like a after market battery. We have no manual.
5 Suggested Answers
jbass706
  • 167 Answers
SOURCE: My 2005 Ford F 350 6.0 diesel starts quits runs
Sounds like a compression leak from one or more injectors into the fuel system. I am guessing that you already changed both the frame and under hood fuel filters in the last 15,000 miles? Be sure the cap on the frame fuel filter is tight, any gap between the cap and housing can cause fuel to return to the tank instead of going filtered o the engine.
Posted on Oct 25, 2009
  • 583 Answers
SOURCE: The selespeed clutch is slipping when
it requires a full service and band adjustment as soon as possible ,more damage is being done each time you drive it .
Posted on Nov 12, 2009
SOURCE: remote and manually not working
one of the batteries was not making proper contact and was loose,had to gently stretch spring contact out to make it stay in place .kept dislodging itself,so far so good.thanks
Posted on Dec 07, 2009
  • 557 Answers
SOURCE: start car trans stops after
low transmission fluid level
Posted on Oct 20, 2010
I've a kr6000d scooter.Always fully charged. When i go out on it the lights start going out. When i stop for a second the lights come back on.Then start going out again when i move. Thanks Mrs M Moore
hi Mrs M Moore, what 's happening to the battery guage when this happens ? does the scooter still do a good distance ?
If not then it's weak batteries...
If yes then we looking at short or component break down that is powering the light circuit...
Regards
Rob
Mar 12, 2016 | Health & Beauty
What could cause the serpentine belt on my 2000 Toyota Land Cruiser to keep breaking after traveling short distances?
Something in the engine compartment is not working correctly, or is misaligned. The increased friction or misalignment could be causing the belt to fail. Needs to be investigated by a qualified mechanic.
Mar 16, 2015 | 2000 Toyota Land Cruiser
My power third row seat don't work, I tested the motors and they work fine when power directly. When I measure the voltage at the connectors I get about +/- 10 volts, from any of the 4 switches. I verified...
Your missing something's G-404 has nothing to do with it !
Seats - Third Row
The third row seat:
  • is three-passenger seat.
  • a 60/40 bench seat.
  • folds down for more cargo area.
  • has optional power fold down seats.
Third Row Power-Fold Seat
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases are on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
The third row power-fold seat consists of the following electrical components:
  • right third row seat relay.
  • left third row seat relay.
  • right power-fold seat motor.
  • left power-fold seat motor.
  • right front third row seat switch (if equipped).
  • left front third row seat switch (if equipped).
  • right rear third row seat switch.
  • left rear third row seat switch.
For the third row power-fold seat to operate, a shared ground is supplied by the body security module (BSM) to both of the power-fold seat relays, enabling the seats to then be moved by pressing one of the third row power-fold seat switches. The third row power-fold seat operates only when the vehicle is in PARK and the liftgate glass, liftgate door or any entry door must be open.
The third row power-fold seat motors transfer movement to a drive gear assembly to raise and lower the seat backrest. The power-fold seat motors rotate a short drive cable which is connected to the drive gear assembly.
The relay's are located in Aux. relay box #2
May 24, 2017 | 2003 Ford Expedition
2002 F 350 super duty cuts off and won't start
Check coil ,module crank sensor chec if it has a strong spark at the plug wire or coil pack if fitted.
Mar 18, 2014 | 2002 Ford F350 Truck Super Duty Crew Cab...
My vehicle toyota corona D4 egine 3s turns off while driving, please help know what could be the problem
my 2005 toyota caldina d4 engine shut off while driving, i change crank shaft sensor, fuel filter, injector driver, air sensor,
May 09, 2012 | Toyota Corona Cars & Trucks
My mouse works when it wants to.
It could be interference or distance from the receiver.
Try moving the receiver. Regular wireless mice can become unstable even at short distances.
Feb 10, 2010 | Logitech V450 Nano Cordless Laser Mouse
My 2005 Ford F 350 6.0 diesel starts quits runs quits. Goes a short distance stalls out hard to start again runs and stalls again. Also check engine light is on. Problem is getting worse after 3 days like...
Oct 25, 2009 | 2005 Ford F 350 Super Duty
When first driving, I hear a high pitched whistling sound while my foot is on the accelerator. As I pick my foot off the accelerator, the sound will stop completely or after a moment or two and then return...
I have the exact same problem, however reversed. My whistling sound stops when I accelerate and starts when my foot is off the accelerator. Frustrates me and am afraid to have it looked at for fear of the cost of fixing this problem. Have you since discovered what the problem is or was?
Oct 12, 2009 | 2004 Jeep Grand Cherokee
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
