1997 kawasaki ZX-6R Ninja Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ninja misfire confusion
I pull away on my ninja fine up to 30 in first or second and then it judder and wont let me go any faster and it keeps misfiring help me please????
Anonymous
Level 3:
Brigadier General:
  • Master 6,966 Answers
  • Posted on Jul 25, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
6966
Questions
17
Helped
3090162
Points
19604
Please see you other post.
2answers
My jeep Cherokee judders when I do between 20-30
Could be anything. Start by having your tires checked.
1helpful
Peugeot partner automatic judders when pulling away.
Do you have a check engine warning light on? It sounds like you may have an engine misfire.
REPLACED CLUTCH ON ZR 550 CLUTCH ENGAGES , BUT WHEN FULLY RELEASED BIKE JUDDERS THEN STALLS OUT . TRY TO ADJUST & GEARS WONT ENGAGE .
So if you raise the revs to say about 4000 rpm and let the clutch out does it stall or judder or both will it engage at all and pull away ?
Mar 07, 2015 • Motorcycles
PSA 2.7l v6 diesel engine judder
use the www.aa1car.com get the topics and fix it.
Car judders when pulling away from rest
check your drive shaft for wear and tear or bend.
Engine light on dash seems car could be misfiring slight judder up to 30 mph replaced plugs problem slightly improved but still occurs can you help
You need to have a code reader hooked up to car so that you can pull the DTC (Diagnostic Trouble Code) code to find out the problem exactly. It could be many things, but it sounds like it could be an EGR problem/Leak.
Oct 04, 2009 • 2007 Ford F
Ninja misfire
Hi and welcome to FixYa,
Offhand, it would appear to be an air / fuel problem.  Initially, check the air box / filter. Verify that there is no air leak and that all air coming in through the carbs passes the filter.  This also happens when the air filter and its enclosure has been replaced with open breathers such as K & N's or the exhaust system has been altered.
Good luck and thank you for asking FixYa.
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
