Question about Element Televison & Video
My tv is only 4 months old and I can not get a picture it is a element tv
I was watching my story and it just went black.
SOURCE: watching rear projection tv.
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Posted on Oct 20, 2008
  • 718 Answers
SOURCE: sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Posted on Mar 10, 2009
budmrtn
  • 11361 Answers
SOURCE: 32" flat screen that went black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 17, 2009
violet09
SOURCE: No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
Posted on Dec 02, 2009
gopakumarg43
  • 74844 Answers
SOURCE: I have a vizio sv470xvt1a while watching tv the screen went black, then picture came back on, a few minutes later it went black again.. No popping noise when it went black. screen is still black...ha
Check and replace the back-light inverter baord.
Posted on Feb 25, 2013
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
Picture went black
Likely power supply failure, especially with the bad smell
Sep 10, 2012 | Element Electronics FLX-3211B 32 in. LCD...
My lg 50inc tv is only 18 months old today we were watching it and the screene went black no picture but sound
That indicates a problem with loose inverters or the inverter board itself needing to be replaced.
Feb 03, 2011 | LG Televison & Video
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
My sony vega is only 4 yrs. old and it went black all of a sudden while we watching it and the lamp light came on
It is possible that your picture tube went out, therefore you would have to either buy a new picture tube and have it installed in the TV or replace the TV altogether. I suggest that you consult the manual that came with the TV. It might be able to help you better. Good luck to you!
Jul 29, 2009 | Sony Televison & Video
After 2years and 9 months the picture went black,
Most likely, capacitors in the power supply are bulged. It is not an expensive repair.
Jul 01, 2009 | Philips Televison & Video
Blown Picture
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
Aug 18, 2008 | Samsung FP-T5884 58 in. Plasma Television
Plasma tv repair question
Thin lines down center of ESA 42"plasma tv, about 1 pixel wide each, about 3/4" to either outside line
Started as 1 then 4 over 4 months
Aug 10, 2008 | Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Televison & Video Logo
26 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
