Question about Refrigerators
The display on the front panel is working erratically
The water and ice stopped working than started again
    An expert who has answered 500 questions.
  • 512 Answers
Some times the wire at the bottom of the door will break partial and intermittently open and close
Posted on Apr 27, 2017
My ice maker will work great for a while, maybe a month or so, & then stop working. It may not work for a week or so and then out of the blue, it starts working again. Hotpoint side by side, about 12...
Good day,
I will assume that the freezer maintains it's normal temperature.
If the temperature in the freezer rises much above 10 degrees the ice maker will lock out. That is by design.
There are 2 possibilities. One is the water valve located in the bottom rear of the machine. Any water valve over 5 years of age is suspect. They will at times refuse to open when the ice maker tells it to, and can become erratic.
If replacing it fails to solve the problem, then unfortunately you will need to repace the ice maker, which at that age would not be abnormal.
If you do the water valve first, and need to follow up with the icemaker itself, nothing is really lost since it is standard proceedure to replace the valve if a new icemaker is installed.
Aug 04, 2010 | Refrigerators
FREEZER ERRATIC. Will work for 6 to 12 hours and
You will have to remove the inside rear freezer panel .The # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to temp setting .
May 02, 2010 | GE PSC25SGSSS Stainless Steel Side by Side...
Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Aug 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Panel flashing, ice door opening and closing constantly
That is a faulty icemaker solenoid switch, or a contact on wiring.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 10, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
