Question about GPS
How do I download gps map for ghana on micrs sd card?
  • 4 Answers
SOURCE: Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
Posted on Aug 24, 2008
SOURCE: Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Posted on Nov 03, 2008
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
Posted on Apr 01, 2009
SOURCE: Panasonic CN-NVD905U SD Card map update download
I bought the map update from Panasonic for $150, even tho it was advertised for $300. I called to order it, and it came with a disk and SD Card.
Posted on May 08, 2009
SOURCE: Garmin C510 wont install download Europe maps to Unit
Take a look at the Garmin support page - there is a Question " Why do I get a not enough space message on my Nuvi2xx when trying to update my mapping?"
It tells you how to remove the unused voice files to free up space.
I have a Nuvi 255WT and deleting the voice files alone was not enough, so I set about removing a lot of other stuff *** NOTE THAT IF YOU FOLLOW WHAT I DID, DO IT AT YOUR OWN RISK **** it worked for me but there is always the risk of deleting a file that the device needs.
Also I was stupid and didn't try and save the files to a directory on my MAC before deleting them, from the satnav - worth a try so that if you can do that you have a chance of recovering one that you delete if you want it back.
First I also removed the un-needed text files - leaving only the 3 British-English files
Then I removed all of the POI files that were clearly examples/samples
Then I removed all of the Vehicle files except the one I was using
Then I removed all of the large ExtData files - now that was the one that caused me the most worry as I wasn't certain what they were there for!
This gave me a bit over 140Mbyte of free space which was enough to install the 2010 update for all of Europe.
Now I don't know whether the C510 has the same amount/less/more memory than the 255WT - so this may or may not work for you.
I didn't have an SD card available, which is why I went this far. I am going to get one and see if I can find out how to load the maps onto that.
cheers - Jeremy
Posted on Dec 01, 2009
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
We downloaded a European map onto the SD card, however, when we look at maps available, the Garmin 260 is not looking at the map on the SD card. How do we tell the device to use the card to search for the...
You need to download the map to your compute rather than the SD card. When downloading the default destination is the satnav but you can change it to your computer. When it's installed to your computer you then click the windows START button and in the list of programs you'll find a GARMIN folder with a program called MAPINSTALL. Connect the satnav to your computer with the SD card in. Run MAPINSTALL and select the SD card as the destination.
You can get more details of how to do it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Note maps installed to SD cards do not always work with Garmin Nuvis. To give it every chance of success please follow the instructions at the above link about formatting the SD card.
Jun 14, 2011 | Garmin nuvi 260W GPS Receiver
My GPS is missing most maps & I cannot seem to transfer from cd
the maps are on the 1gb sd card in the side of your c220 unit.
If it's missing, get a 1gb sd card and find a computer that will accept sd cards and your cd that came with your gps, then download the maps from the cd to the sd card.
Your c220 only has 4 states on the unit itself.
The c230 has all the maps on the unit but only 1 million POIs versus 3 1/2 million on the c220
Mar 12, 2009 | Mitac DigiWalker C230 GPS Receiver
Mar 11, 2009 | Panasonic Strada CN-NVD905U GPS Receiver
Map on tomtom go 300
The downloaded maps can be copied direct to the SD card or copied to the SD card via USB lead and PC connected through TomTom Home. Once you have the map on your SD card you will need to activate it with your product code number that you obtained when you purchased the map.
Good luck
Sep 01, 2008 | Tomtom GO 300 GPS Receiver
Vista HCX Micro SD Problem
Vista only recognize gmapsupp.img files.Go to www.mapwel.biz/down.htm take MapUpload software then from mapsource select maps you want to transfer to sd card.Or directly from Mapsource select Transfer and send selected map to sd card.Maps must be unlocked.
Aug 19, 2008 | Garmin eTrex Vista GPS Receiver
Enzer jor-001 gps
1. Go to http://www.enzersa.co.za/GPSDownload.html
2. Download the SA Maps Version 6 upgrade.
3. Follow the instructions:
How to use
1: Download South African Maps.zip to your computer
2: Open the zip folder and copy the content by right clicking and copy
3: Insert the SD Card from the GPS unit into the computer.
4: Now open the card through my computer
5: Replace the DestinatorApps folder with the new one
4. Replace the SD card in the Enzer and there you have it!
Best of luck!
Jul 21, 2008 | GPS
Map loading from SD card
Yes go to the Lowrance web site and down load the fix to a sd card , put the sd card in the i finder and it will update it automaticlly. I have not done it for map create 7.0 but have for map create 6.3. On the web site look under suport or downloads and you should find it. There is also a lot of free lake maps that you can download to sd card also. Good luck
budman630
Feb 11, 2008 | Lowrance iFinder GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
SC card
I am not able to look at the map, as it always direct me back to my home. How can I solve the problem ?
Mar 21, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
