Question about Kitchen Ranges
Have may tag MGR7775WB ser. No. 14710064 all 4 burners won't light and oven won't light all at same time what is wrong could this be fuse and where are they located
SOURCE: top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Posted on Dec 07, 2008
meztang
  • 112 Answers
SOURCE: i have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
  • 2006 Answers
SOURCE: burners work fine, pilot light
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Posted on Aug 28, 2011
  • 37 Answers
SOURCE: oven won't light
REMOVE BACK PANEL AND CHECK THERMAL COUPLING ,LONG THIN TUBE BRASS OR COPPER,SHOULD BE PILOT LIGHT ON CLOSE TO COUPLING,IF NO LIGHT, MAY HAVE TO CALL GAS COMPANY, THEY POSSIBLY WILL LIGHT IT FOR YOU,MUST BE QUALIFIED TO DO THIS ,LIABILTY PURPASES...
Posted on Feb 18, 2012
richroth
  • 9472 Answers
SOURCE: Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Posted on Dec 02, 2012
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
MAYTAG WGR7775WB OVEN INGNITER NOT WORKING
the wire that goes into the oven might be clogged and have to be taken apart. call repair man.
Nov 14, 2012 | Maytag MGR7775WB
I melted some butter in the oven, it dripped into the burner holes and now they won't light.
i would let do this by specialist,to clean the burner.
butter can also ignite or you can get gas bubbles,not safe
Jul 26, 2012 | Stoves Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Top burners often wont light if oven is already lit
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
