Question about The Computers & Internet
How do I change the ssid in the hp8600? Will not conect to router.
    Master:
  • 263 Answers
Cant conect chromecast on WAG200G
verify it is trying to connect to correct SSID - verify p/w entered correctly - verify MAC address is allowed in router.
chk to see if router is seeing chromecast asking for access.
Oct 12, 2014 | Linksys WAG200G Wireless Router
How to find thewep or wpa
Routers are normaly shiped with the SSID on the back along withe the Pass key{password} if this has been alterd then you will need to conect up your router with a ethernet cable to a computer and open up you browser and type 192.168.0.1 this will take you to your router setup page you will need the admin password to change your ssid and passkey
Aug 17, 2014 | D-Link Computers & Internet
Lost my ssid on router seems to have reset somehow
Enable your SSID broadcast on your router, if not shown, insert SSID and/or password(if needed) manually.
Apr 13, 2014 | TP-LINK Computers & Internet
I bought a toshiba 6100 it has wireless card but i cant seem to figure out how to change it to conect to my wireless broadband conection
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 23, 2011 | Toshiba Satellite Pro 6100 Notebook
Cannot conect to internet wireslay; used to be able, but now have to use cable attached to router
Good Day,
check the WEP, WPA, WPAPSK of your router and the SSID there's a chance that it was changed, so check the setting of your router and the wireless NIC in your laptop if it's still working.
Good luck.
May 23, 2011 | NetGear Computers & Internet
I have windows xp d I cant get the router to conect to it with security active
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Nov 05, 2010 | Gateway Belkin F5D7230-4 802.11g Wireless...
Cannot conect to router wirelessly although have a strong signal
Sep 25, 2010 | Belkin (F5D72304F5D7000) Router
Everything has been checked out. and is working. now is time to see if it is the router. I can get on line only if I conect with cable. no wireless. It was working.
Hi fine so i do understand u are able to go online wired but not wireless....just try these steps
Step 1: Connect modem>>router>>computer
Step 2: Open the browser page and type http://192.168.2.1
Step 3: Towards the left coloumn click on channel and ssid below wireless
Step 4: Change the channel to 11
Step 5: Assign ur own ssid name-any name as u prefer
Step 6: Checked broadcast ssid is enabled or checked
Step 7: Then apply changes
Step 8: Then click on the security below channel and ssid
Step 9: Select the security type as 64 bit wep
Step 10: Type any 10 numbers make note of those nos thats ur password
Step 11: THen disconnect the connection between router and laptop
Step 12: Tried scan and connect
Step 13: U wiil see the network created by u select that and connect
It will surely work out
Aug 21, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have one dlink access point moden cable conection.that net work coming.dlink.but i want network name:access point. how i can change that name
Login to the web-server "inside" the router, and then change the SSID from 'dlink' to your desired name. Also, change from "no encryption" to "WPA" encryption.
Aug 21, 2010 | Computers & Internet
Latitude X1 PC Notebook: I just used ny Dell Latitude X1 to add a new lapto...
If the other laptop can't see the network, then it sounds like you somehow turned off SSID broadcasting while you were in the router's settings. Log back into your router and look for the SSID broadcast enable setting. Make sure it is set to on, then save the changes and reset the router if you have to. The laptop should be able to see it now. (There is also a setting in the Windows wireless network properties that you can check to connect to a network even if it is not broadcasting, as long as you have connected to it previously.)
Hope that helps!
May 17, 2010 | Dell Latitude X1 Notebook
Computers & Internet Logo
46 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
