Question about Kenmore Ovens
Kenmore stove, used self cleaning for lower oven, this afternoon and now it does not heat up passed 100 . The model # is C970-600391
  • 1314 Answers
SOURCE: kenmore stove
try pushing stop clear
Posted on Dec 29, 2007
  • 8 Answers
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
jyackle5
  • 8197 Answers
SOURCE: I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
Posted on Dec 18, 2008
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 | Ovens
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Good Luck
Dec 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore self cleaning oven model 790.9520 : element stays on
sounds like it was in the preheat mode the cent to the cook mode so you can cook
Dec 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Self cleaning oven directions
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
