How do i reset my machine back to 15 seconds - Washing Machines
How do I unlock the controls on my kitchenaid washing machine?
To unlock the controls press and hold the CYCLE END SIGNAL for 3 seconds and that will unlock the controls
Oct 10, 2011 | KitchenAid KHWS01PMT Front Load Washer
I forgot my password. I am using SMCWBR14-G. What can I do?
On your wireless router it will have reset button.
There is a very small button on the back of your router get a pen and click on it and hold for 10 seconds and it will reset your router.
(remember to have power on) Linksys IP number is 192.168.1.1
type this in the address bar at the very top of your computer screen then hit enter. A window will appear, in the password section type (admin) and it should let you in. If you can`t access it wireless connect a ethernet cable to one of the 1 - 4 ports and to your pc.
Here is a youtube video how you reset it:
http://www.youtube.com/watch?v=zOp-zkn4JsY
More here:
http://www.youtube.com/watch?v=RAXKapuKjlQ&feature=related
http://www.youtube.com/watch?v=r8OOFNTMMeE&feature=related
Hope this will help you
May 05, 2011 | SMC Barricade g SMCWBR14-G (662698582192)...
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite washer and the light is on that says controls locked
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
Mar 10, 2011 | Kenmore Washing Machines
The control lock light is on and i cannot get the controls to unlock. what do i do?
OR
OR
Feb 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have the Linksys Wireless-G WRT54GS Router and when i plug it into my modem, no lights come on, besides the power light which was already lit. I've tried resetting it (holding the reset button for 30...
There is another way to reset the router called hard reset..
you need to hold down the reset button for 45 seconds while its turned ON and don't let it go.
After first 15 seconds, take the power cable out but still keep holding down the reset.
After second 15 seconds, insert the power cable back in but still keep holding down reset.
After last 15 seconds, release reset and turn off the router for 30 seconds.
0-15 = Power ON, Reset button Pressed in
15-30= Power OFF, Reset still Pressed in
30-45= Power ON, Reset still Pressed in
If it still doesn't work then you got a bad router, can't be fixed. :-(
Feb 13, 2011 | Linksys Wireless-G WRT54G Router
No codes given control light flashing on selector knob but machine will not start
Your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Feb 08, 2011 | Whirlpool GHW9100L Front Load Washer
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
Jan 11, 2010 | D-Link Computers & Internet
Power light blinking not working cannot re set
Was there any power flicker before it happened?
1. Reset the router by pressing the reset button of the router for 15 seconds while the power cord is plugged in and while the router is powered on.
2. Release Reset button after 15 seconds and unplug the power cord of the router then press the reset button again for 15 seconds.
3. After 15 seconds release the reset button and replug the power cord then press the reset button again for 15 seconds.
If this didn't work.
1. Plug the power cord to the router, and unplug it do this 7 times then reset for 15 seconds while it's unplugged and plug it back it and press the reset button for 15 seconds and release it. Try to check if there's any changes.
Jan 09, 2010 | Linksys Wireless-N WRT150N Router
Master reset for pc
Unplug your machine from wall outlet. Open the case and remove the flat battery from the motherboard. Wait 5-15 minutes and replace it, your machine is now at default settings.
If this helps plz take the time to write a couple of word testimonial. Thanks.
Oct 19, 2009 | Compaq Presario 5000 PC Desktop
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
