Question about The Computers & Internet
My 2000 grand am se ran out of gas after putting it back in it still wont start so I was told do reset the relay for it but I don't know where it is or how to even do it can u help g me find it
They said to reset the switch but how do i do it
    Top Expert:
  • The Master
  • 14,309 Answers
Grand am no inertia switch only fuse and fuel pump relay
Posted on Apr 27, 2017
Ran out of gas and now wont start 1994 jeep grand cherokee
check the installation of fuel injection or carburetor your...
Jan 16, 2012 | 1994 Jeep Grand Cherokee
Starting problems
Might be your key or ignition if it has the computer chip in key to enable start-up. don-ohio
Dec 19, 2011 | 2000 Mercury Grand Marquis
Replaced the fuel pump and filter on a 2001 pontiac grand am se. car wont start is there anything else or filter keeping the gas from going to the engine?
dont know if I can help but make sure the fuel pump comes on for a few seconds when you turn the ignition on if not check the relay under the hood you may need someone to help with this there are 4 terminals when you pull the relay out one will have power all the time with the key on another one will have power for a few seconds when you first turn the ignition on if you have power there and the fuel pump dosent run at all the relay may be bad you can also check the connection by the fuel tank for power when you turn the ignition on also I just put a fuel pump in my sons 2000 grand am and it did not start after I put the pump in but I could hear the pump running but we had only put a couple of gallons of gas in so I put another 3 gallons of gas in and it started I also just put a pump in my daughters 2001 grand am and it started right away but I had put 5 gallons of gas in right away You can also see if there is fuel pressure at the fuel rail on the right side or passenger side of the engine there is a connection to check fuel pressure you can take the cap off and use a screwdriver to push the valvestem in to see if there is fuel there and any pressure. if you have power to the fuel pump and plenty of gas and the pump wont run try hitting the bottom of the fuel tank under the fuel pump with a ribber hammer
Sep 17, 2011 | 2001 Pontiac Grand Am SE
I have a 2000 grand am and I ran it out of gas. I put gas in it.
look for the fule rail on top of the motor there should be a release looks like a tire vavle stem push that in and see if you can get fuel to come out that should purge your fuel system if that doesnt work then your fuel pump may have gone out
May 22, 2010 | 2000 Pontiac Grand Am GT
I ran my 2000 xterra dry, put gas in the tank and it still wont crank. where is the fuel reset button located?
There is no fuel reset button. You either burnt out the fuel pump relay or burnt out the relay and fuel pump.
May 03, 2010 | 2000 Nissan Xterra
My 2003 Chevy 1500 ran out of gas and wont start?
you will probably need to reset the fuel shut off relay.
Feb 25, 2010 | 2000 Chevrolet Suburban
2000 cavalier if it dosn't have a reset utton for fuel pump
most likely cause would be dirt in the fuel filter from running out of gas or the pump got burned up.try cycling the key about 4 times to prime the pump and see if it starts
Apr 26, 2009 | 2000 Chevrolet Cavalier
Car wont start after running out of gas
Try a new fuel filter. you most likely sucked up some junk or maybe water from the tank when it ran out. Check fuel pump make sure it runs.
Feb 04, 2009 | 2001 Pontiac Grand Am SE
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
