Question about Sony Televison & Video
Help my Sony bravia kdl32l4000 has a blue screen and no sound I can't change the channel or anything I can only turn it on and off. The light doesn't blink a code either
  • 8 Answers
SOURCE: no picture or menu
If your dealer has not already told you, I suggest you unplug the unit from the wall and let it sit for 30-45min. Plug it back in and hope...
Posted on May 04, 2007
  • 734 Answers
SOURCE: Remote Codes for new Sony Bravia
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:
Posted on Nov 17, 2008
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
  • 153 Answers
SOURCE: sony bravia lcd
Sounds like a possible T-con board failure. Which would need to be done by experienced tv repairman
Posted on Jul 22, 2010
MY tv that goes straight to the screensaver mode like it would on pc. sony bravia kdl32nl140 is the tv.
J, it sounds like it may not be getting any input from cable or satellite, try switching cable and inputs around, try VCR or DVD player. You may need a firmware or software update.
Some forums say to unplug and wait 10 min. then it resets.
Check links below.
Sony eSupport KDL 32NL140 Support
Stuck with initial setup screens on my Sony Bravia 4k Android TV
Feb 21, 2016 | Televison & Video
Have a sony Bravia 32L4000 that wont turn on
seems to be fine? replace the main power board
Jul 23, 2017 | Sony KDL32L4000 32 in. LCD HDTV
My rca whp141 doesn't seem to work with my Sony 32 Bravia Kdl32L4000. Can't get the light to light up on the base Please
Press the menu button from the remote, look for "Settings". You should have a "Sound" category. Once you've located that, press Enter to go into the submenu. You want to look for "Audio Out" option and change it from the default "Variable" to "Fixed". Then you should have sound in your headphone. You can just either mute or lower the volume of your TV. Hope this help.
Jun 30, 2010 | RCA WHP141 Consumer Headphones
Sound but no picture on my Sony Bravia KDL-32W5810.
no u need to bring it to the nearest service// maybe u have memory ic problem.
Feb 27, 2010 | Televison & Video
Re: Sony Bravia remote problems
sounds like you need to "autoprogram" your channels. In the customer menu search for "settings" (looks like a toolbox) select that, arrow down to "channels" select that, you'll see option for "autoprogram" select that. Any channel it sees it will lock in and you shouldn't have to press numbers anymore.
Apr 27, 2009 | Televison & Video
Blue screen, have AUDIO ON ALL CHANNELS!
Make sure video cable is connected on right socket. for instance AV1. test cable box on other tv to see if it is transmiiiting picture. If so make sure your tv is tuned to cable box if using RF cable or on slected av mode where av cable is connected
Apr 07, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDL 40 HD
it's in a service test mode. have you unplugged the tv? that should reset the tv..if you still have problems after will need repair.
Sep 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
SONY xbr screen problem
It sounds like one of your circuit boards may be going out. I'm sorry I don't have a better response than that.
Jan 20, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
