Question about GE Ovens
Test error message on GE oven - GE Ovens
Self-clean-mode not working, I get the "door" error message
are you sure it is an auto lock door and not a manual locking type .
Oct 22, 2015 | GE Ovens
GE oven displays an F 7 error message
Hi Mark, Why not search online for this error code + ge oven? You'll get the info you need but don't necessarily want!
Jul 15, 2015 | GE Ovens
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
What is error message F7 mean in GE Wall Oven?
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jan 31, 2010 | GE Ovens
ERROR MESSAGE 5F
This fault concerns the relay drive circuit. If this fault code cannot be canceled, replace the oven control (also called clock or ERC).
Jul 26, 2009 | GE JKP15 Electric Single Oven
F7 error on GE eledtric oven JKP20
This is a shorted touch pad. replace the touch pad or, if the touch pad is incorporated within the control board, replace the entire oven control board.
Jun 25, 2009 | GE JTP20 Electric Single Oven
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
Ovens Logo
24 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
