Question about The Computers & Internet
Hp8600, the printer is on a different ssid # . I do not know how to change to my network.please help.
cinek79
  • 320 Answers
SOURCE: Hi, I'm trying to create a
you need check what mode is operating your printer 802.11g or 802.11b and enable this on your router
Posted on Aug 08, 2008
rakeshpramod
  • 234 Answers
SOURCE: please can you help me
Network Security Key or WEP Key is peovided by your Router company.
You can call then and get the same>
If not if the operating system is WinXP then go to start> Run> Under run Type CMD> press ok> then in the black dos window> Type IPCONFIG.
Now you will see IP Address And Default gaetway>
Copy the default i.c192.168.1.0. and close this window.
No open a inter explorer window.
In the adress bar type http://192.168.1.0 and press enter>
It may ask for user name and password it should be Admin (User Name) Admin (Password) and hit OK>
You should now have the setup screen for your router. Go to the "wireless" tab and you should see your WEP key,
Good Luck
Posted on Oct 04, 2008
kakee
  • 1269 Answers
SOURCE: attempting connection of a hp photosmart 7200 printer
What is the brand of your wireless router? Just make sure the SSID (signal's name) is configured on the wireless setting of your printer. They should have the same SSID configured. If the correct SSID is already configured on the printer's wireless settings, try to change the channel on your wireless router. Use channel 11. You can also try to do a power cycle. Turn off your wireless router and printer for about 1 minute. Power on router first, wait for the lights to stop blinking, then power on your printer.
Posted on Oct 14, 2008
  • 59 Answers
SOURCE: Wireless Printer will not print wireless or connected
do you have the program disc if you do then inset it to the computer and hit restart installation and then follow the steps but make your you know your router name (SSID) first.
Posted on May 17, 2009
Morikvendi
  • 56 Answers
SOURCE: HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Posted on Jun 01, 2009
I dont know my SSID code
The wireless router has a default SSID usually it is the router manufacrurer's name, you should change this SSID to something different to make your wireless router secure.
Connect a LAN cable from the router to the LAN port on your computer, open a browser and enter the router's configuration URL and go to the wireless settings to change the SSID.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 14, 2011 | Computers & Internet
Change my printers ssid name
The SSID stands for "Service Set Identifier" it is the name of your wireless network name. The SSID is not usually required in configuring a printer.
The SSID is configured in the router's wireless settings.
To secure your wireless network from unauthorized access including configuring the SSID, please click on this link and follow my instructions :-
Aug 23, 2010 | Computers & Internet
Just had windows 7 put on my machine, but have lost my network please could u tell me which nmber(and there is a few on back of Belkin) is my network security key please
The default wireless network name/SSID is found underneath your router. It looks something like Belkin_N1_Wireless_123456. If you cannot see the SSID in the available networks on your wireless computer, then you might have changed it to a different name.
Use a computer that has connection to the router to access the setup page. Use a browser and type 192.168.2.1 in the address bar.
Go to Wireless -> Channel and SSID. You can change the SSID to any name that you want. Then make sure that Broadcast SSID is checked. So that the computer will be able to detect the SSID.
For the network key, go to the Security tab. If WPA is set, copy the Pre-shared key. If you are using WEP, you will need to take note of the 10 digits (64bits) or 26 digits (128bits) wep key.
I hope this helps!
Mar 04, 2010 | Belkin N1 Vision Wireless Router
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
My system crashed & when I called lynksys I
The easiest way of course id to return the router back to the SSID you used originally. Configuring your PC to use that SSID would be much less problem.
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Have BROTHER PRINTER that will accept wireless, It needs ssid to operate. i am using vista 64 bit. can u help me please
The SSID is the name of your wireless router assuming you have one. That series of printer isn't designed for PC to Printer direct wireless but rather to have your PC print over the network connection through the router to the printer.
If you do have a wireless router and just don't know the SSID, go to your wireless computer/laptops networking screen in control panel and view the available wireless networks. The one you're connected to is yours. The name displayed in that window is the SSID you need to enter into the printer.
Note: you will also require the routers password if it is a secure router.
Hope this helps,
Chris
Jul 09, 2009 | Dell Computers & Internet
Connecting copier machine wireless
Configuration using a wireless computer.
  1. If your computer has wireless capability, you will need to change the wireless settings of your computer to Ad-hoc mode so you can directly connect and configure the printer.
  2. Wireless network terms and concepts
    When you configure the wireless network printer, you must ensure that your wireless network printer is
    configured to match the settings of the existing wireless network. This section provides some of the main
    terms and concepts of these settings, which may be helpful when you configure the wireless network printer.
    SSID (Service Set Identifier) and channels
    You need to configure the SSID and a channel to specify the wireless network you want to connect to.
    SSID
    Each wireless network has its own unique network name and it is technically referred to as SSID or ESSID
    (Extended Service Set Identifier). The SSID is a 32-byte or less value and is assigned to the access point.
    The wireless network devices you want to associate to the wireless network should match the access point.
    The access point and wireless network devices regularly send wireless packets (referred to as a beacon)
    which has the SSID information. When your wireless network device receives a beacon, you can identify the
    wireless network that is close enough for the radio waves to reach your device.
    Channels
    Wireless networks use channels. Each wireless channel is on a different frequency. There are up to 14 different channels that can be used when using a wireless network. However, in many countries the number of channels available are restricted. For further information, see Ethernet wireless network on page 165.
    Authentication and encryption Most wireless networks use some kind of security settings. These security settings define the authentication (how the device identifies itself to the network) and encryption (how the data is encrypted as it is sent on the
    network). If you do not correctly specify these options when you are configuring your Brother wireless device, it will not be able to connect to the wireless network. Therefore care must be taken when configuring these options. Please refer to the information below to see which authentication and encryption methods your Brother wireless device supports.
    Authentication methods
    The Brother printer supports the following methods:
    • Open system
    Wireless devices are allowed access the network without any authentication.
    • Shared key
    A secret pre-determined key is shared by all devices that will access the wireless network.
    The Brother printer uses the WEP keys as the pre-determined key.
  3. I will advise you download this network manual and follow the instructions on chapters 3 and 4.
  4. Network Users Manual - English
Apr 15, 2009 | Brother HL-4070CDW Printer
Mar 30, 2009 | HP PhotoSmart C4385 All-in-One Printer
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
