Question about Power Computers & Internet
After the initial start up screen my tv monitor goes black. The light on back of unit, power and alarm light are red. I onlpppy haveva mouse blpn
The System has functioned before. Also I have vga,bnc,hdmi cables available.
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
likha
  • 790 Answers
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
byteguy
  • 2229 Answers
SOURCE: Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Posted on Nov 05, 2009
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computers & Internet
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
Jul 03, 2009 | Computers & Internet
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
My Monitor Is Going Crazy
have you tried to check if your pc is infected by virus? you should update your anit virus.
Mar 24, 2009 | Compaq Computers & Internet
Screen goes to sleep after "no signal" message
If you do not move the mouse or press any key on the keyboard it could be just going into video power save. Confirm it by moving the mouse or pressing a key on the keyboard. If the monitor comes back on, adjust the power settings in control panel and change the time for the "turn off display" to a more suitable setting.
Dec 31, 2008 | ViewSonic VA1930WM LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Screen goes blank when I move the mouse
please be specific, your question is not understood properly??
Oct 26, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
27 people viewed this question
Top Power Computers & Internet Experts
john smith
Sattech
Level 1 Expert
MonsterByte
Level 1 Expert
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
