Question about Garden
Brigs Stratton engine stops at first compression point, when attempting to start. Has a new battery. Turning back manually and trying to resart, gets same results. help
  • Garden Master
  • 3,828 Answers
If an older briggs engine say 8-15 hp
electric start may have sheared the flywheel key a fraction and put timing out
valve seats may have come loose and jammed a valve
or con rod come adrift
pop the head of the motor off and inspect
Posted on Apr 27, 2017
Why is there no fire to spark plug on 6 hp brigs & stratton engine
replace your ignition module and or coil,i dought you have points and condenser,so basically that's all that is left
Aug 01, 2014 | Briggs & Stratton Garden
18hp v twin brigs when it runs oil comes out of carb
you will see a tube coming from engine block to carb, pull it loose at carb just under the air intake or right behind breather filter. start engine and if oil blows out then its a blown head gasket.
Jun 21, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Won't start
What engine do you have?
May 20, 2013 | 1989 Ford Bronco
S2046 low battery tried to start. Replaced battery now no sound, no start. Yes did hook up correct cables. Where can I find images of safety switches?
When trying to start with a low battery the engine Sometimes will stop on the top of the firing stroke putting it under extreme compression..almost like being stuck..you must turn tne engine backward a little just enough to get it off the compresdion stroke then try and start..This very same no click no nothing even when jump start happened to my cub cadet this summer after trying to start with a low battery...i used a pipe wrench and turned the dry shaft back and it started..then and all summer...give it a try good luck..
Nov 14, 2012 | Briggs & Stratton Starter Scott's Equip...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs 17hp intek overheadvalve on a john deere L100 has developed a hard start hard spin on compression stroke. new battery new starter
hi there
pauly46 here
if engine seems to labour when trying to start as if too much compression ?
try adjusting to in and ex valve clearance to 0.003" inlet and 0.005" ex
inlet valve is the bottom valve, and has a alloy push rod. ex valve is top valve and has steel push rod ( as viewed from the front of the machine with rocker cover off ) )
note rotate engine with plug out to tdc compression stroke , then rotate it down the bore on power stroke by 1/4 inch ( 6.35 mm ) this is the point for setting in / ex valve clearances
manual says 1/4 pst tdc on compression stroke - this eliminates decompressor lift from the setting
cheers hope it hepls
May 01, 2011 | Briggs & Stratton Garden
2004 John Deere 118 tractor, 22HP Intek engine. New battery, but still won't turn engine. I can manually turn it by the pulley but the starter just clicks....when it did work, the starter took a couple of...
It sounds like a starter problem. If the starter was used heavily -long runs or multiple times to start the engine- it could be shorted. Overheating is the enemy of the starters and happens when a starter is used hard to start a balky engine. Repalcing the starter isn't a big job and many B&S engines use the same starter. Find a working starter, replace yours with it and try to start the engine (with clean plug and full battery.)
It is also very possible that the compression relief valve is malfunctioning. It s mounted on the cam shaft and opens the exhaust valve to bleed compression from the cylinder(s) when starting. When it doesn't hold the valve open the starter can't throw the cylinder past top dead center TDC) to relieve compression. The work around is this: turning the pulley manually past TDC will allow a good starter and fully charged battery and clean plug to turn the engine and fire.
B&S has a high failure rate for the compression relief valve and states that the valve clearances are critical for the valve to function properly. And when the engine is worn and valve clearances are set right but it still malfunctions... the company has various reasons why YOU caused the problem.
Replacing the compression relief valve etc takes 3-5 hours and at $65+/hr you can see what the cost is- not including the relief valve which costs somewhere around a $100 (more for larger engines.) Even after replacement, it might not fix the problem.
Dec 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
