Question about Stanton Audio Players & Recorders
My Stanton T52 turntable makes a banging sound near the spindle when spinning, does anyone know why
nick_helpap
  • 334 Answers
SOURCE: turntable Spinning too fast
ya buy new belt loose or is this direct drive
Posted on Oct 09, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
SOURCE: Stanton ST150 turntable won't spin
Hello DeKay,
I just had a spindle lock issue this past Sunday at my gig. I had the turntables out in my car and brought them in. I let then warm up for 2hrs before plugging them in.
Everything was good. Then mid set my right side turntable started spinning really fast and then DEAD STOP.
I was pushing the platter and it really hard to turn. I took off the platter and tried to turn it with my hand. It was dead locked, WTF?!!
So I limped through with one turntables since I use Traktor Scratch Pro and made it through the whole night successfully.
I searched the net and it was suggested to lubricate the 1200 spindle with 15W40 motor oil. Since the motor design is indentical, I picked up some 10W40 motor oil since I couldn't find 15W40.
I oiled both turntables to be on the safe since. I tapped the spindle on the locked turntable to help loosen it.
I drove back home which is pretty much an hour drive and let the tables sit for another 2 hrs.
I decided to grab a thick towel and vice grips to work on the locked spindle.
Clamping down on the towel with the vice grips on the brass fitting for the platter I was able to free the spindle quite easily.
I was then able to turn it by hands so I did in both forward and reverse directions to work the oil down into the spindle bearings.
I put the platter back on and spun it manually to check for resistance, it was spinning nicely!
Plugged in the turntable, set the pitch at 0 and watched the stobe dots. There was no waver in the strobe dots. YAAAAAAAY!
My turntable is back to new and since I only use them on the road they stay stored most of the time.
So I would suggest just oiling the spindles every so often to keep them tip top.
Hope this helps you!
Peace,
DJ Quartz
Posted on Feb 18, 2009
SOURCE: Stanton Turntable Problem with receiver/audio
You need a turntable pre-amp, or a receiver with turntable inputs.. The turntable is functioning properly, until recently no turntable had this built-in. Search ebay for turntable pre-amp and you should be good.
Posted on Oct 26, 2009
heatman101
  • 43501 Answers
SOURCE: Dryer is making a banging noise? Sounds like
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Apr 18, 2010
Stanton T50 turntables.There is left/right play in the spindle which means the platter wobbles when pressure is put on it.Anyone know how to strip the top of the turntable to get to the spindle base?
Like most turntables, you have to strip the top of the platter of it's covers to get to what is holding the spindle in place. The cover might be held with glue. So you just have to force it off. You can glue it back after you have done. I suspect the spindle will be held by a horseshoe clip. Again another tricky thing to get off.
Nov 13, 2016 | Stanton Audio Players & Recorders
Stanton T52 turntable static
Tricky. I would suggest running a wire to a earth point such as a copper pipe, say of a radiator. A lot of static could be caused by yourself when handling an record. Some carpets make this worse. You can get an anti-static earth strap for yourself, when you handle the records.
http://www.amazon.co.uk/s/ref=nb_sb_ss_c_0_7?url=search-alias%3Delectronics&field-keywords=anti+static+wrist+strap&sprefix=Static+%2Caps%2C177
Feb 22, 2015 | Stanton T52 Turntable
Stanton T52 Turntable. I get intermittent, loud popping, like static. I have checked ground wire, and it is hooked up to receiver just fine. I have cleaned my LPs in every way possible and have tried 3...
There are 3 possibilities I believe here. First a faulty connection to the cartridge or the cartridge itself. (2) internal (inside the deck) fault on a pre-amp. (3) Fault on the magnetic cartridge pre-amp in your amplifier. This would not effect any other functions on the amp.
How can I stop rumbling noise from my Pioneer PL-J210 turntable?
Well looking at the newprice, i would buy a new one/, but you have a belt drive platter and it it works as easy as a carengine - and the belt which turns the transformer, which goes via pullies which maybe in your case is just worn out, but first try a bit oil. And check the belt quality. If it is the motor, which i doubt , i wouldnt put any money in it , since they the unit is 60euro new.
greets holland
Jun 18, 2014 | Stanton T52 Turntable
Need a new belt
The best I can suggest is that you measure the diameter of the belt in mm and put that into google search with the words "turntable drive belt". Hopefully something should come up! I would suggest contacting Stanton, but I couldn't find the website for the company, so that might be a waste of time, but if you want to try have a go!
Feb 08, 2014 | Stanton T52 Turntable
Internal fuse
Unfortunately, there can be too many causes for this. For more information, please visit my website at audioserviceclinic.com. Thank you.
Sep 27, 2013 | Stanton T52 Turntable
Oct 04, 2009 | Audio Players & Recorders
Low audio
Make sure it's plugged into the PHONO section. There's a good reason they label it for that - only Phono requires PRE-amplification to boost the tiny signal from the cartridge to a suitable level for the following stages to use.
Apr 04, 2009 | Stanton T.90USB Turntable
35 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
