Question about Blue Computers & Internet
Windows shuts down unexpectedly blue screen - Blue Computers & Internet
    New Friend:
    Problem Solver:
  • 5 Answers
It'll be probably due to the overheating of your cpu. Just check whether all system fans if your cpu are working.. If it is check the moulding of fan to the motberboard.
Posted on Apr 27, 2017
maeayanami
  • 20 Answers
SOURCE: Blue screen w/msg: A promblem has been detected and windows has been shut down to prevent damage to your computer.
If the video card is ok try to reset your motherboard. just open your cpu and look for a battery on the board. (be sure your pc in unplugged) remove the battery by pressing the little lever in the bottom part of the battery after a few seconds place it back again just by pushing it.
Try also disk cleanup, disk defragmenter and system file checker...
hope this helps...
note: system file checker works works with the windows disk, it restores corrupted system files with a new one...
Posted on Aug 25, 2008
dragon_sun25
  • 107 Answers
SOURCE: My Dell Dimension 4400 running
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
Posted on Dec 08, 2008
SOURCE: Blue Screen of Death
You'll need to setup the Acer laptop to boot from CD-ROM. Push either the F2 or F10 button when booting your laptop and it should bring-up the configuration management interface. Go through the options and confirm that Boot From CD-ROM is at the top of the list on bootable devices.
Next, you'll need your original Windows XP CD that came with the Laptop. Put it in the CD-ROM Drive and reboot your laptop. You will be given two options: 1) Re-install Windows or 2) Repair the existing Windows Installation. I recommend that you repair the existing Windows Installation as this will not destroy and data or device drivers that are install on the laptop.
Good Luck!
Posted on Dec 16, 2008
frankzjm
  • 191 Answers
SOURCE: blue screen c000021a fatal system error
usually blue screen comes from unstable video memory or windows system or HD.
you may try
1) reinstall windows
2) change another HD to install windows
3) change new ram memory or change memories slot between one and another
if not fixed, to be sure your video memory damage which is insualted on board(separated with RAM), only the hardware repair can be fixed.
Posted on Jan 23, 2009
intower18
  • 957 Answers
SOURCE: my computer went to a
Dear Sir,
Please have the problem solved by having the system
repaired. This is actually being caused due to a corrupted
or missing system file. Please have the instructions to
having it repaired
Repairing Windows XP using CD installation
The CD installation for windows XP allow you to repair windows whenever there is file missing or corruption or improper function of Windows. This tips can be useful before you opt for a complete format to your computer.
Your first step is to boot the computer using the cd installation.
Below message will display:
Press Enter to setup Windows and accept the license agreement. Then select the XP installation you want to repair and then press R. 1wq9asrj-2-s-.png
Windows xp will copy necessary before reboot. You will be asked to press any key to boot to the CD. nzlmbj8t-2-s-.png
Do not press any key. Windows will boot to installation screen automatically and start installation.
After installation, enter the CD key (windows registration key) to finish repair.
You can now remove the cd from the cd drive and reboot the computer for appraisal
Posted on Jul 16, 2011
Blue screen unable to restart windows10
A stop error (also called a "blue screen" error) can occur if a problem causes your PC to shut down or restart unexpectedly. When you experience this type of error, you won't be able to see things like the Start menu or the taskbar on the screen when your PC is turned on. Instead you might see a blue screen with a message that your PC ran into a problem and needs to restart.
If you see a stop error while you are upgrading to Windows 10, setup will automatically go back to your previous version of Windows.
If the error continues, try to fix it by removing software or hardware.
Sep 22, 2017 | Blue Computers & Internet
Hello i have an HP windows 7 i turned it on and it goes to blue hp screen and freezes up
A blue screen error usually comes up on Windows 7 when there is a serious hardware or software issue that may be causing Windows to Shut Down unexpectedly. At times, a message may also come up on your screen saying "Windows has been shut down to prevent damage to your computer."
To troubleshoot this issue, you may need to try out multiple troubleshooting options to detect whether the issue is with your hardware or software and to resolve the same as per the recommended procedure.
To know more about your troubleshooting options to get rid of blue screen error, you need to refer to the following Microsoft and HP support pages:
http://windows.microsoft.com/en-in/windows7/resolving-stop-blue-screen-errors-in-windows-7
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00372711#N182
The above troubleshooting steps may also help you to resolve the freezing issue. If they don't, please let us know so that we can suggest you additional troubleshooting options for the same.
GuruAid.com
Jul 13, 2014 | Computers & Internet
Blue screen of death
Blue screen error is basically related to hardware or driver issues in Windows . This error blocks users from logging onto their Windows operating system. Windows can shut down or restart unexpectedly......fix blue screen error
If you need any kind of technical assistance, you can contact support cell at http://www.vtechsquad.com
Sep 11, 2012 | Sony Computers & Internet
How to fix unexpected shutdown due to Blue screen problem of Pavilion HDX9494NR
See if the Check disk utility will solve your problem. To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | HP Pavilion HDX9494NR Notebook PC
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
May 20, 2010 | Acer Aspire 6530-5143 Notebook PC
Blue screen Fatal System Error. How do I get the laptop to work?
damaged OS windows or most commom hard drive failer..
Apr 23, 2009 | Dell Inspiron 2200 Notebook
Presario desktop windows vista, shuts down unexpectedly
Windows Vista will not install on old computers. If this is your case try installing Windows XP, If this does not work you might want to try Linux (Ubuntu). which will run on almost any old computer with full capabilities.
It is free and you can download it from
http://www.ubuntu.com/
Feb 26, 2009 | Computers & Internet
Windows shuts down unexpectedly, also Product Host not working
Restart the PC and if the problem persist check your RAM or any new hardware installation. Sometime you may need to Restore the System to the previous state.
Jan 30, 2009 | eMachines Computers & Internet
Blue screen c000021a fatal system error
you may try
Jan 23, 2009 | HP Compaq nc6320 Notebook
Computers & Internet Logo
27 people viewed this question
Top Blue Computers & Internet Experts
salaberrios
salaberrios
Level 1 Expert
Bill Boyd
Gunn
Level 1 Expert
Are you a Blue Computer and Internet Expert? Answer questions, earn points and help others
