Can't close the door - the machine will run . How do I shut the Door ... now it's left open all the time???
  • Brad Brown Apr 26, 2017
    Hi John Kerwin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make and model number?
  • Washing Mach... Master
  • 3,828 Answers
Safety on /off switch door catch broken or hinges to re set
gaffer tape the door closed till repaired
Posted on Apr 26, 2017
When I switch on my washing machine AEG Lavamat turbo 16800 it displays E40
HI Mike.
THIS IS ALL I COULD FIND OUT.
E40 relates to the door being left open when the programme is started, it maybe that the latch was not pushed over when the door was shut.
to solve the problem get another switch.
hope this helps you.
or read up some more at this link.
washing machine AEG Lavamat turbo 16800 it displays E40 Google Search
Dec 20, 2017 | AEG Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
Samsung sensor quick P801 can't close the door. The main front door can not be close easily. I take me 6 to 7 try to close it. Sometime I need to slap the door firmly. The Door seem to be close but just...
you should not be able to open or close the door with the washer ON. You must first shut off machine before closing the door, then turn the machine ON, this should lock the door closed. to open the door, you must shut the machine OFF, then the door should open easily. Follow the directions in the manual... you can Download the owners manual here, in your language of choice; Follow the link below. just copy and paste it into you browsers window.
http://www.usersmanualguide.com/samsung/washing_machine__drum_type/p801
Don't forget to rate the answer.
Jan 24, 2011 | Samsung Washing Machines
The machine will "hang" with
Check the pump sump cleaner. Under the front panel at the bottom. DC means the door is still sensed as open . If it occurs more often may need new door lock switch
Oct 29, 2010 | Maytag MAH8700A Front Load Washer
Older maytag dryer: rewiring help
If it is a usual door switch, it is simply OPEN or CLOSED (the switch im talking about ... not the door.) Translation, it doesnt make any difference. When the wires are connected in the switch, the machine thinks the door is closed. When they are apart, the machine thinks the door is open.
Make sense?
(Maybe)
Two wires one switch it is a 'switch leg'
If I read this incorrectly, please tell me. (I answer the belt question all the time ... I usually remind people to be careful of the door switch ... )
Thanks for using FixYa.com
Positive comments always welcome.
a
Oct 28, 2009 | Dryers
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
U 1 error message
U1 is a right cover open error. So either that cover is not closed all the way, the tab on the door itself is not hitting the sensor that detects if it is closed, the sensor itself isn't working properly and lastly it could be board malfunctions. Most times on this model it is either a broken tab on the door or it is not shutting correctly. The front door has to be completely shut before the right door will shut. If you are looking at the right dooor straight on the sensor is at the bottom left corner of the machine. There is a little **** in the plastic that is where the sensor is. There is a piece of plastic on a spring that is on a guide that slides back when "triggered" some times that can come off the guide.
Hope this helps.
Dec 31, 2008 | Panasonic DP-150A Copier
Washer has stopped spinning, also the unit will have time left on the timer and it shuts off
it is the door switch,the pin on the door pushes a swith when you close the door as a safety this is installed so the washer doesnt spin while the door is open,open the door you should see 2 screws which hold it up
Jul 07, 2008 | Maytag Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
