Question about HP Garden
Brigs stratton rider mower engine. 17.5 hp - HP Garden
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
  • 110 Answers
SOURCE: want a repair manual for a 17 hp briggs &
A range of strip-down manuals for all Briggs & Stratton engines is avalable - I got mine from Amazon, but you can get them directly from Briggs & Stratton via their web site. They have a look-up system by model series, which ensures you end up with the manual that covers your engine.
Posted on Oct 03, 2009
  • 39 Answers
SOURCE: briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Posted on Mar 14, 2010
  • 2841 Answers
SOURCE: Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Posted on Apr 23, 2010
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
Posted on Jul 29, 2010
Valve heads carbond up on 24 hp brigs and stration
That's a pretty common problem on small engines, but I never heard of brigs and stration! If that really the name, I am surprised that the real Briggs & Stratton did not sue them for trademark infringement, since it looks somewhat similar!
May 15, 2017 | HP Garden
Tightening sequence for briggs and stratton 17.5 hp engine
tighten bolts opisite of each other snug then one 1/4 turn to tork
Oct 06, 2014 | Briggs AND Stratton Intek Briggs &...
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
For single....the are in 1/2 HP ratings but the link is below....
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Why is there no fire to spark plug on 6 hp brigs & stratton engine
replace your ignition module and or coil,i dought you have points and condenser,so basically that's all that is left
Aug 01, 2014 | Briggs & Stratton Garden
Which valve is the intake valve on a 17 hp briggs engine?
look at the valve s one is smaller than the other one this is the intake the big one is the exhaust valve
Jun 11, 2014 | Briggs AND Stratton Intek Briggs &...
My briggs and stratton 8 hp engine on my mower sometimes just clicks when i turn the key after a few clicks it might start
sounds like your battery is going bad, try it with battery charger hooked to battery see if that helps
May 16, 2011 | Tecumseh Ov691ea 22 Hp 22hp Lawn Rider...
17 hp 42'' rider with hydrostat with hand controls wont move.... mis their oil in the rearend?????? or what else could it be,the belt is on
mowre will start but will not go into gear shaft will turn but not engage how can i get to trany without complete breakdown of *** end
Jun 27, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
23 people viewed this question
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
