Question about Stihl Garden
How do you remove the handle of a Stihl 017 chainsaw?
It seems to be a single wraparound piece with no screws?
    New Friend:
  • 11 Answers
On the right hand side of the handle there are 3 plastic plugs covering the screws that go through the anti-vibration bushings
Posted on Apr 28, 2017
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Chainsaw blade rotating when idling
Could be dirt in the carb or a dirty air filter. A good clean is in order I think!
Feb 04, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Stihl ms660 ilde chain speed to fast
Somewhere on the carb linkage you will see a set screw touching it. Turn the screw so it does not push the linkage so far.
Apr 14, 2013 | RTO Spur Sprocket For Stihl 017, 021...
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
Jan 10, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Have a lose wire on a stihl 021 chainsaw by air filter but don,t know where it goes to
It probably goes to the ground on the choke lever. Remove the air filter and look at the area where the shut off switch is located, you should see a small slot where the wire slides in and connects with a metal piece in the stop position.
Apr 05, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
How do you replace spur sprocket on a 038ab stihl chaninsaw? how do you remove the sprocket that is over to the right of the spur sprocket?
To remove the sprocket on this saw you must remove the oiler gear that sits in the way. Remove the mounting screws for the oiler gear plate and you are home free.
I hope it helps
look for parts at a local dealer like www.arcolawn.com
joe
Feb 03, 2011 | RTO Spur Sprocket For Stihl 017, 021...
Stihl 048 tank vent tube???? why does it have little set screws at either end?
the set screws restrict fuel flow out of the vent while allowing air to enter the tank
Sep 25, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
95 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
