Question about LG Washing Machines
Lg wt5170hv fills but won't wash; did this before unplugged and replugged started up. Now this doesn't solve prob. start stop sw. doesn't work have to replug to stop to open lid.
  • 641 Answers
SOURCE: washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Posted on Jul 26, 2007
  • 4 Answers
SOURCE: LG front load washing machine will not spin
I am having the same problem with my washer. Go to this web site below it has a free troubleshooting guide. I narrowed my washer machine down to two parts. Stator assy or Main PWB assy.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Posted on Oct 13, 2008
  • 38 Answers
SOURCE: Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Posted on Sep 26, 2009
freetek
  • 5568 Answers
SOURCE: machine won't start- checked plug -didn't start-
Make sure that the AC receptacle has voltage by plugging in another device. If it is dead, the breaker servicing that outlet may have tripped (without reason, I've replaced a couple of failed breakers) or the outlet may be protected by a 'Ground Fault Interrupter' (GFI). If this is tripped it would be due to either a momentary imbalance of the line or possibly electrical leakage within the washer. This latter problem needs to be cured as it presents a safety hazard if the GFI fails to trip as it should.
Posted on Dec 14, 2009
  • 130 Answers
SOURCE: We have an Overhead garage door. It has started
A bad circuit board or capasitor will cause this, mostly its the circuitboard. Depending on the age replace it with a Chamberlain/Sears opener or they make a model called LIFTMASTER you can only get this thru a garage door company.
Posted on Aug 09, 2010
How do you remove inner drum on top loading LG Washer WT5170HV?
The whole top of machine must be removed.
unplug electronics and hoses remove upper splash ring remove cap in center of agitator remove bolt holding down remove .
remove inner tub Nut center tube should lift up and out.
next step if your changing shaft is all from bottom.
lot more down there. Take picture b4 and as you remove for ref. to resemble
Jul 03, 2016 | LG Wave WT5170HV 27" Top-Load Washer with...
My lg wd-80134t does not spin
Try pressing the "Temp" and "Option" buttons simultaneously for 3 seconds, check if the machine will start, if not unplug the mains supply for a couple of minutes, replug and check whether all the buttons are working and that it will start.
Jun 04, 2015 | LG Washing Machines
Tub is puncturing the drainage hose
balance the machine and level the machine..see waht happens.
Mar 31, 2014 | LG WT5170HV
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
Auto Programme starts up every time I turn on my LG 42PX5D TV. I've had it for 3 years and only started to happen yesterday
Unplug it,for a couple hours.Replug it back should stop.Not check ur manual contol see any buttons stuck in plastic that held the manual contol board.Might have to replaced the manual control board to solved this problem.
Feb 06, 2010 | LG 42PX5D 42 in. Plasma HDTV
Oct 10, 2008 | LG WM-1832C Front Load Washer
FE error?
But does anyone knows what FE means?
Mar 05, 2007 | LG WD-3274RHD Front Load Washer / Dryer
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
