Question about Sony KP-51HW40 51" Rear Projection Television
Green colour and curved lines
My sony projection TV has curved lines and green colours .
  • 18 Answers
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives you more specific instructions.
I hope this helps you!
Fare well. :)
Iconoclast
Posted on Jul 27, 2009
  • 42 Answers
PLEASE POST MODEL # for an accurate response!
But it sounds like a convergence problem.
Posted on Jul 25, 2009
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Tv gone green/blue and sometimes red in top right corner
If you have a Sony rear projection LCD TV then you have a failing optics block. LCD TV's are not affected by external magnets like CRT TV's were. The optics block issue will only get worse and needs to be repaired by a technician.
Sep 10, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KDF-55WF655 55" LCD Projection TV
I have the same TV and the same problem, I take out the block of colours red, green and blue (the blue colour is broken) and I went to the electronic supplies for ask the price  and they don't sell just the little blue mirror (blue pixel), they sell all block for $2,050.00 dollars. It's the price for a new one
Oct 09, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KP-57WS500 57 in. Rear Projection Television
Hi Guys
Your problem here has to do with the amount of aging that happens to the three colour tubes - red, green and blue.
Blue actually ages slower than red and green. What actually happens is the green tube deteriorates and due to green being the predominant colour for brightness causes the blue tube`s flyback lines to appear - especially when switching between inputs or when the video is blanked.
No replacing the blue tube will not solve your problem as the tube is actually the best one of the three.
As someone mentioned there is a way to adjust this by removing the speaker grill assembly in front of the set. Doing the service mode adjustment with the remote is not the right way to solve the problem - you would be adjusting the colour gain and off-set values and would seriously be compromising the white balance of the set.
On the left hand side behind the speaker cover you will see a black square block with six adjustment points. Look for the one marked SCR BLUE, Switch the set to a unused input so the blue lines become visible. Now adjust the BLUE point counter clockwise until the lines disappear. A small adjustment should do it, Switch back to a picture and make sure the whites are still white.
This should sort your problem. I would however suggest asking a Sony service centre to do this for you. This is a dangerous thing to do as you will be working close to the 35Kv supply the the anodes of the three tubes.
I hope this answers your question.
Goo luck.
Jun 05, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
230 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
