Question about Soleus Heating & Cooling
How do i clean my soleus fan - Soleus Heating & Cooling
Soleus Air FSH-40G fan would not start. The bad seems harder to rotate. what could have gone wrong? How to fix?
First unplug the fan for safety. Next add a couple drops of motor oil on the shaft that turns with the fan blade. Tip the fan blade at about a 45 degree angle when adding the motor oil. Spin the blade by hand at that same angle to allow the motor oil to flow down the shaft, inside where you cannot see the shaft. It should start turning by hand a lot easier now.
Sep 06, 2015 | Soleus Dryers
What does the "swing" button do on the soleus ac/heat remote control?
The swing button on the unit itself turns on the horizontal oscillation of the louvers. The remote's swing button adjusts the speed of the oscillation. In the fan mode, it lets the Soleus Air Conditioner circulate more air.
Home Depot has the manual for Soleus PH3-12R-03 here: http://www.homedepot.com/catalog/pdfimages/d4/d4382c05-2692-4075-a254-fdcdef6dc1fb.pdf . The buttons are the same across the units.
I hope this helps.
Jul 17, 2014 | Soleus Heating & Cooling
How to keep the fan speed on low at all times on the Soleus Air MAC-10K? Every time we adjust it to low after about 10 minutes it automatically changes fan speed to high and it does not go back to low...
dear sir
i think your air conditioner,s micro controller system is not working well, that why this problem is coming .please contact to your product dealer for replace it .
hope answer the question
thank you
please vote!
Sep 29, 2010 | Soleus MAC-10K Air Conditioner
Soleus CFM40E
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
contact@soleusair.com
Jun 26, 2008 | Soleus CFM-40 Dehumidifier
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Soleus KFR-18 Air Conditioner Problem
Check your thermostat settings at heat mode.
Jan 03, 2008 | Soleus KFR-18 Air Conditioner
Solebus heating
yes, it is intended that way. I also have a Soleus and a special manual addendum sheet was inside the manual and it pointed out this feature..I think Soleus had a lot of customer phone-ins over this...I guess the idea for the exhaust is to withdraw moisture from the room, since anytime air is heated or cooled, moisture is a by-product that must be eliminated.
Nov 03, 2007 | Soleus KY-34 Portable Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
