Front wheel bearing replacement on a vw golf Mk 3
You'll need to remove the spindle, by removing the axleshaft nut, disconnecting the lower ball joint, unbolt the 2 bolts holding on the strut, and the brake caliper, carrier and rotor. You will need to press out the hub, (the part that the lug bolts go into. Then remove the snap ring on both sides of the bearing, and press out the bearing. Reverse for installation.
